What Can I Do To Make It Louder?
X pipe, Y pipe, to 2 smaller magnaflows? Does that make sense? Obviously I have no idea what I'm talking about here :thumbs: But I would like to stay with magnaflow, but just get more rumble out of it. I currently have 3"SI/ 2.5"DO w/ 4" 45'd rolled tips. Muffler size is 21" overall x 5" x 11" I think. Any advice and how to's are greatly appriciated. Thanks in advance everybody... Oh, and if you want to see how it sounds currently you can check it out on the bottom of my sig. I have 2 videos, I would look at just the exhaust one. Thanks again...
X pipe, Y pipe, to 2 smaller magnaflows? Does that make sense? Obviously I have no idea what I'm talking about here :eek: But I would like to stay with magnaflow, but just get more rumble out of it. I currently have 3"SI/ 2.5"DO w/ 4" 45'd rolled tips. Muffler size is 21" overall x 5" x 11" I think. Any advice and how to's are greatly appriciated. Thanks in advance everybody... Oh, and if you want to see how it sounds currently you can check it out on the bottom of my sig. I have 2 videos, I would look at just the exhaust one. Thanks again...
X pipes will give you a better exhaust flow and enhance the sound created by whatever magnaflow you get. The sound will be similar to the Corvette. :rollin:
Yeah, shorter muffler would make it louder. But it sounds pretty good as it is. You can always go louder, but doesn't necessarily mean it'll sound better. :rollin:
thanks alwcurlz for the suggestion, i really don't know what an "x" pipe does though? also thank you for the comment omegafiler! and zembonez, why you want me to take it off? sound that bad huh? :rollin: thanks again everybody! oh yeah, stevens07, i've been searching for a smaller muffler with 3"SI/2.5"DO but can't seem to find one that magnaflow makes? know of a place?
thanks alwcurlz for the suggestion, i really don't know what an "x" pipe does though? also thank you for the comment omegafiler! and zembonez, why you want me to take it off? sound that bad huh? :cool: thanks again everybody! oh yeah, stevens07, i've been searching for a smaller muffler with 3"SI/2.5"DO but can't seem to find one that magnaflow makes? know of a place?
An X pipe is a balance pipe. It aids in creating a vacuum effect known as scavenging. It will not help you for your current set up. An X-pipe is for "true dual" exhaust. It will also not make your truck louder. I love how an X/H pipe make a vehicle sound, but it will actually quiet them down a bit. But unless you want to redo your entire system, it doesn't matter.
Check Jegs.com for a magnaflow....part number 642-12198 is a 14 inch SI 3/DO 2.5
and part number 642-12288 is an 18 inch.
magnaflow
Speaking of Magnaflow, u get the Nova fixed up?
No, I haven't worked on it much yet. We may have to pull the heads. We are going to have to get busy though, if we are going to get it done before May 15-17th. All the plug wires look good, and are not that old, but I think we will replace them first. Just to be sure.
:cool:
I hope u get it fixed up, I wanna see that bitch run
You and me both! All this nice weather and not being able to drive it is making me sick. Don't get me wrong, I love driving the camaro, but I want to drive my own car!
thanks alwcurlz for the suggestion, i really don't know what an "x" pipe does though? also thank you for the comment omegafiler! and zembonez, why you want me to take it off? sound that bad huh? :lol: thanks again everybody! oh yeah, stevens07, i've been searching for a smaller muffler with 3"SI/2.5"DO but can't seem to find one that magnaflow makes? know of a place?
thanks 66nova for going into detail about an x pipe. i really don't want to redo my setup like you said, so i've been eye balling that 14" body muffler. i currently have model #12588 which is a 22" body muffler. what would you say would be the effects of going smaller? i really love magnaflows sound, think it will be a real obvious difference in that deep tone? thanks again...
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
