Anybody In Here A Jeweler?
Zembonez
I want to have a ring made.
Anybody in here a jeweler or have one in the family?
Here is an example. I want one of the two on the left in 14 or 18K gold.
I have a guy.
I had my wife's engagement and wedding rings custom made by this guy as I wanted zero chance of anyone having one just like either of them. He did great work. He's worked for Celine Dion, John Mellencamp, and others. Hell, he even made a chalice for the pope once. He does the engraving for the Indy 500 trophy even. :thumbs:
He has a line of racing inspired rings that I've seen. Perhaps he has one of these. I can ask him tomorrow as his offices are in our building, if you'd like. :lol:
I have a guy.
I'm down with that. Thanks!
I like the idea of a tire tread wedding ring. I haven't worn a ring for the last 15 years and Mrs Clown would really like it. I figure she has enough damn rings for both of us but I'd wear the tire ring because it's cool and it would make her happy.
I have a guy.
He has a line of racing inspired rings that I've seen. Perhaps he has one of these. I can ask him tomorrow as his offices are in our building, if you'd like. :D
I'll talk to him tomorrow then. :lol:
hook me up with one of those but dont make it real gold. silver would be fine how much do u think that would cost anyways? not like i got the money or anything :thumbs:
I have had a guy.
:thumbs:
Don't get that weaksauce tread pattern Jim.
Get like the BFG KDW tread pattern :thumbs:
I'd totally rock one of those rings. Those are cool.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
