Sound System Install 07 Nbs
So I was lookin thru 08 denali's thread on his install and I felt inclined to do one of my own. I have just started and haven't gotten very far but its beginning.
So far I have 2 gauge wire run from the battery to a distribution block that has 4 gauge outputs at the amp rack, which is going to be located behind the extended cab seats, never to be seen again (well, until more upgrades arise). I upgraded the "big 3" using 2 gauge power wire, a 200amp breaker, and 4 gauge grounds. I also made the amp rack out of 1/4" particle board.
I'm sticking with the stock head unit for now, thinking about a CarPC for the future, The subs are the main priority at the moment and the interiors will be coming soon.
For subs I have a pair of Audiobahn 10" DUBs rated at 600RMS
Amps are two Kenwood KAC-8152D's running at 550RMS x 1
and one Kenwood KAC-X541 rated at 124RMS x 4
I do have a Diamond audio component set as well which will eventually be replacing the stock fronts.
Altho you won't be able to see the amps I wanted it to have a more finished look when I have to get back there, so I dragged an interior panel into Joanne's Fabric and found a vinyl that looks quite like the same color tan.
I'm not going ape shit on the dynamat but I do have some laying around, not too sure if its going to cooperate being that its been rolled in its box for over 6-7 years but if not, I'm not worried. I figured I would lay it on the floor under the carpet where the subthump box will be firing the subs.
As always, any comments, concerns, criticisms are always welcome. :thumbs:
Right now I am just hoping the test fit with the seats back in position is successful! :D
Good Luck! You will have to let me know how the back seat fits since at the rate I'm going it will be Christmas before the seat goes back in. :shakehead: I like the idea with the vinyl but why particle board? Just had some lying around? Like I said good luck on the install and I'm looking forward to the finished product!
Keep us updated!
Good luck!! Let me know how it turns out, I'm bout to put my stuff back in my 09, been a little curious about the space back there...
Here's a small pic of my 06 amp rack if your interested....
damn talls, thats a nice setup! Real clean!
The space is extremely tight! I did a test fit of the seats back there with the amp rack installed. They fit just fine with the seats in the bench position, but once you try and fold them up, the back half of the anchors for the child restraint system get in the way and smack the amps. I cut them off with a cut off wheel. Leaving the front part which is also a mount for the upholstery. With them out of the way, when you fold the seats up, they don't hit the amps, tho I wouldn't recommend using those restraints anymore. My thought is that most car seats don't have that ability to use them anyway, and I don't plan on a future with kids so I think I'm ok. So if you are looking to flame me for that, find someplace else. Just be sure to cover every part of the seat so not to burn thru anything...
oh, yea, the particle board was just layin around. I'm not really sure how I am going to mount the board to the truck tho. Denali, how did you mount yours? I really don't wanna bore holes thru the truck and all that's behind it the wall now is the outside. Any ideas?
Thank you Sir! :D
Yeah I was concerned about the space, I wonder if it would be ok since I don't really need to lift the seats up much at all. My sub box will be there and I have a car seat and a booster back there....
I was nervous about that too, a buddy of mine did it and he basically use sheet metal screws and silicone. I never had any issues with leaks or anything like that. Just make sure the screws aren't too long and hit the bed...
Thank you Sir! :D
ok, it seems to be alright as long as you don't want to lift the seats up, its going to be tight installing the seats back in tho. You might end up scratching one of the amps. My seat goes back up about half way without cutting off the attachments before hitting the amps. Like I said, I don't intend on having kids and you can always put a car seat in the old fashioned way anyway. I think I am going to go with the sheet metal screw and silicone route unless someone else has a better idea.
Thats great to hear about the seat fitment. I figured that the child restraint system would probably need to go. You might be able to retain it if you place your amps in just the right spots on the back wall. Its not worth the headache for me though.
I attached the amp board to the wall using some heavy duty construction adhesive. IIRC it was the PL400 stuff from Home Depot. So far I haven't had any issues with it coming off the wall and I don't expect to in the future. That adhesive is hardcore to say the least. Once the board is on there it is NOT coming off in one peice.
PL400? WoooooooooW! Really? Hahaha! I wouldn't have thought about doing that! I think I might look into it tho!
Yea, I didn't really have a choice with the child restraints, my amps are over 15 inches a piece, I believe if you wanted too, denali, you could get away with it as your amps are far smaller, about 5 inches.
Oh, and I didn't have room for the jack, it hits the amps, so I threw it in the spare tire.
lol, with all that extra weight from the sound deadening I can't imagine a spare and jack would mean that much more.
I was able to mount my amp on a shelf style bracket as close to the back wall as possible, allowing me to raise my seat about 98% of the way up. No big deal to me beacuse with a seat cover on its a pain to raise it anyways.
I think I am going to mount it to t-nuts that are going to be tack welded to the back wall. Pretty much the only way not to drill thru the wall that I can see. Not saying the welding isn't going to ruin the paint...
well between the weather and werk I finally got a chance to werk on it once more! Thank gawd! I'm really getting tired of not driving it! For the most part all I have to do is tap into the wiring for the speakers and be done with it... for now. Interior speakers aren't getting installed just yet. Tho I may in fact change my mind.
I installed T-nuts in the back of the rack mounting the amps
Then I wrapped it in the tan vinyl
As you can see, I have no idea how you are stupposed to fold the material over internal edges (if that makes any sense) but I thought it came out alright.
Yup, I know I'm missing a screw, apparently some other lowes customer felt that they needed one of the screws from the bags I bought more than I did... and I didn't notice it.
Thats all for tonight, back to lowes tomorrow and hopefully it will be mounted and my truck back in one piece until I order the sub enclosure. Money is tight.
Wow! That really looks good. You did a good job with the vinyl. I get to try my hand at that in a few weeks when I'm done fiberglassing my a-pillars. I hope they turn out as good as yours.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
