The highlight of my day @ the AS
General Lee 01
There were these race cars from a local VA race team on display in the show.
One of the guys from the team was on hand (I think he was the crew chief for the car I was looking at) and he saw me looking around it enthusiastically and he asked me if I would like to sit in the car.
I imediately said yes and he "helped" me into the car. He strapped me into the seat with the full 5-point harness and let me look around in it for awhile. So while I was checking it out he and my mom got into a conversation about what their team does, how they operate, hpw they hire drivers and how their drivers run up through the ranks.
So after I get out we get into a 15 minute disscussion. He told me how to get started. He said the starting series is called the "U-Sprint" (Or something like that),and it's Ford Probes and etc. (4 cylinder american cars.) He said they have funny rules. The cars have to have working horns and working radios.
And he talked to us for a good while and got me all excited about racing, so I may be driving a race car in a couple of years. :D
There's an 80% chance I'm going back to the show tommorow, so I may try to talk to the guy again and see if I can't "Get a deal going".  :D
Sweet!!  It would be a ton of fun to get to race cars.   :D
I have found my sport of choice that I want to learn and master, just have to find a place to learn.  And what sport might that be: Skelaton.  That's right, I realllly want to do this.  Racing down an ice track at 80+, headfirst!!  :D If anyone on here participates in Skelaton, let me know, I would love any info.  :D
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
