Do You Think It Is A Fair Price
VR021302
How much would you charge for the following repairs? (labor only)
1990 jeep cherokee 4.0, 4-speed auto 2wd
rear diff service
pinion seal
rear shocks
front pump seal
rear main seal
oil pan gasket
oil filter housing gasket
upper and lower radiator hoses
heater control valve
brake inspection
This is all for a "brother" of mine that can't afford this to be done at a shop.
:D
Minus parts, $550....
Plus what the hell is "oil filter housing gasket"? You know the new oil filters come with gaskets. :thumbs:
:D
The housing that mounts to the block that the oil filter mounts to. It has 3 o-rings that seal it.
How long do you expect this all to take? Tell him beer and food if its for a "brother." Make sure he helps out too!
Oh it's done already. It took about 10 hours this weekend. On the garage floor, no air tools either.
I was paid $250 cash, plus an amp, sub and wiring. Suyb was $135 new, less than a yr ago, amp was around $300 if I remember right when I bought it about 10 yrs ago, and the wiring is about $80 i think.
So total value minus depreciation is at least $400
EDIT: He fed me on sat. night, and he brought beer.
I didn't want him helping because he is mechanicaly inclined, he screws everything up.
:D
:D
Well thats good. HAHA, I know all about the friends who have zero mechanical skills. I had a couple friends come over to help with my lift. I just told them that there wasn't enough room under the truck. They just handed me tools.
Yeah, the last person you need helping is someone that is mechanically inclined. :lol:
:D
Oh, and part of the payment was an amp that YOU bought about 10 yrs ago? Sounds like a helluva deal. :D
Well the amp, sub, and wiring was mine, but I sold him a truck in Jan., or whenever it was I bought my GM and it was the system in the Dodge that I sold to him. I didnt feel like pulling iot out when I sold it, but now im getting it back anyway.
:D
apparently you didnt read the rest of it sir.
:D
apparently you don't know what "mechanically inclined" means. :D
:D
I saw that too and was hoping it was a typo.
I didn't want him helping because he isn't mechanicaly inclined, he screws everything up.
fixed,I have friends like that too.I tell them''step away from the car'' and hand me a 1/2 -9/16 box end wrench.He says ''huh'',go get me a fWONking beer :lol:
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
