Removing Left Front Axle Shaft Bearing
Hello. I just bought a 1999 Silverado 4x4 Z71, new body style. It has a 5.3L.
The left front axle shaft seal was leaking so I got the shaft out and the seal but I can't figure out how to get the bearing out. It looks like there is a tab that I have to bent and then pull it out somehow.
What is the procedure for pulling this bearing? The shaft had a lot of up and down play so I really want to get it changed. Thank you.
Well, for anyone doing this in the future use a pinion bearing puller. It didnt want to come out at first, but it worked really good to take it out. Wasn't too bad to do, if you go to get the parts the parts places around here had it listed as the inner axle bearing and outer axle shaft seal just for reference. No one could understand what I wanted.
  • 6 months later...
The inner axle shaft seal began to leak on my 06 Z71 Silverado so I decided to replace the inner axle shaft seal. I picked up a new seal from Auto Zone (hey, they even gave me the correct seal, go figure) but once I got the old seal out from the axle shaft, I was better able to inspect the inner bearing for wear. Three of the roller bearings within the race were beginning to show some signs of wear although the axle shaft itself where it rides in the bearing looked smooth and perfect. Since I know that slack in the bearing will certainly lead to the new seal failure, I decided to remove and clean the bearing in solvent for better inspection and slipping it over the axle shaft I discovered it was very loose around the shaft. So I called Auto Zone to see if they had the bearing in stock only to discover they had no idea what I was talking about. Since the sales person was a lady, I took time out to accurately describe what bearing I need for my truck and that I had only a few days ago purchased from them the seal which goes in front of this bearing. She finally told me they don't stock or show this part. I thanked her and then called O'Reillys. Not good results there either. The guy who answered the phone kept telling me I was looking for the axle wheel/hub bearing, for pitty sake! When I finally argued the correct part I was needing, he simply told me my Z71 truck didn't have an "inner axle shaft". I asked for the manager and after rehashing the account, was still not able to get results. In frustration, I finally asked him if all his bearings came from China, to which he answered, YES! I told him that was good information to know because I didn't want to buy parts for my truck, especially bearings, that came from China so told him thanks and hung up the phone. A friend told me NAPA sells Timken bearings. I haven't tried NAPA yet because they are closed today but I searched their online store and could only come up with a NAPA part number BRG B2010. It shows a picture of the bearing which looks exactly like mine BUT the inside/outside specifications don't match up to my bearing, so I don't think this is the correct bearing. Advance Auto Parts don't show a listing for the "inner axle shaft bearing" either. Looks like I may have to go to a bearing specialist store to get the correct bearing. I hate buying bearings online because you never know if you will get the correct part or not.
  • 3 months later...
hello
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
