Stern Free This Week On Xm.
I know its a bit late but has anyone been able to get him in there truck? I have been listening all week on the net but channel 100 and 101 are not coming options in my truck.
XM site makes you fill out an on-line form to get your free trial......
I didn't do it... just not a stern fan. There were some hoops you had to jump thru.
Interesting. I got it in mine. Not a big Stern guy at all, he stopped being funny to me years ago. I heard the promo in the MLB channel and thought I would see what, if anything I was missing. Turns out he still isn't funny, but I did get channel 100 without a problem.
I switched over to xLBlue after that. Now those guys are funny!
When I had Sirius I never listened to him. Never found it entertaining. I primarily had satellite radio for music anyways, I hated commercials. Now in my new truck I don't listen to XM at all. I don't feel like subscribing and "wasting" money. Seems like music content has gone downhill in the past year, so now I use my mp3 player.
No Howard Stern?
Sometimes blessings come in odd ways. :thumbs:
I would not walk accross the street to speak to this guy much less listen to anything he has to say.
Just not a fan of him in anyway at all.
He is certainly not worth even a small fraction of the 100 million dollars a year they supposedly pay him. No wonder they almost filed for bankruptcy.
That he got that out of them just shows what a genius he is.
His movie Private Parts should have been called Back When I Was Funny.
Not a fan at all of anything he's done in about 15 years.
thanks for all the opinions. you know what they say about them. i still dont get it in my truck though. and i tried that blue collar radio... :D
just going to stick with O&A and Ellis i guess.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
