Burned Turn Signal Fuse
I burned the fuse for my turn signals on my 04 Denali when I tried tapping the wires to a compressor for a train horn. Bad move, I know. So I'm looking through my fuse box and can't figure out which to replace. I took a bunch out and looked at them but none seemed burned. Can anyone help? And is it possible that it's not a burned fuse?
Thanks
So basically to confirm you blew the turn signal circuit/fuse... You tapped into a wire for the train horn, then something overloaded or whatever, then the turn signals stopped working. Correct? And everything else is still working OK?
The fuse on my 92 for this is called "Turn". Look for a fuse with a "Turn" label. Then replace the fuse even if it looks OK and see if the new fuse fixes the problem. It may be labeled under each fuse, or on a fuse cover, or in your owner's manual.
Of you don't have a fuse called "Turn", check each fuse with a continuity tester. A multimeter can do this when set to ohms. You place both leads together and get a reading on the meter. A good fuse would get a reading whereas a burned out fuse would get no reading (like you had the test leads in the air).
Also might check the wire you spliced into. Be sure it was not totally cut. Be sure that spot in the wire is still good.
Let us know what happens...
Yea, that's the right fuse box, but which one do i replace? There are four different ones that say turn, each for different sides or other things. But since I only tapped the wires on one of my headlights, wouldn't I only need to replace one, and the others should still work? Or are they somehow connected?
I'm going to try and replace the fuse labeled LT TRN, seeing as how I tapped the left headlight, tomorrow morning. Thanks again for the help.
Please be specific as to the EXACT problem. ("Turn signals" not working is an entirely different problem from "turn signal" not working!)
Does the right turn signal work? Is it just the left turn signal which does not work?
When you turn on the left turn signal, does one light come on in the rear?
Do you have a multimeter? Can you test each fuse for "continuity"?
Do you know how to test a fuse to see if it is good or not?
sorry, its actually the dayrunning lights that are not working. the turn signals still come on. i tried replacing the turn signal fuses but that did not work. so any idea as to what it is?
thanks again
thanks again
Should be a fuse for the DRLs, check that bad boy out. There may be multiple fuses, the 900s have 2 in series for some reason. Or say screw it, DRLs are useless in USA.
Go to an auto parts store (or wally mart), and buy a multimeter. Use it to check the related fuses. You can buy a fuse tester, that will light up when you place the leads on the fuse leads. Good luck.
so how do i fix that? are these under the hood fuses or are they in the fuse box? sorry im not very truck savvy
Ok, that is what we need to know. The exact problem as well as what you need help with.
If you need more detailed instructions, then that can be done. Just ask!
As to checking fuses, it sounds like your Day Time Running lights fuse has blown. You can find information about which fuse is located where in your owners manual sometimes. Or on the outside cover of the fuse box sometimes. Or on the inside cover of the fuse box sometimes. Or marked below each fuse.
Look for Daytime Running Lights or DRL.
Then a fuse is sort of like a light bulb. There is a little wire inside which can break and it no longer works. Just like a light bulb.
You can look at the fuse and see if the little wire has broken.
Or you can test with a "continuity tester" (multimeter) to see if it still is connecting the electricity from one prong on the fuse to the other prong on the fuse.
As mentioned above, I suggest you go to radio shack and buy a multimeter. Have the guy there show you how to use it to test a fuse.
Following is a simple web page which also shows you how to test a fuse with a multimeter, but ask for more instruction at Radio Shack too. The more you learn about how to do this, the better you will understand.
How to test a fuse...
http://www.dinosaurelectronics.com/Test_Fuse.htm
So I'm almost positive I've found the fuse to replace. It's not one of the smaller two-pronged fuses. It's one of the larger, cube-sized ones with four prongs. I'm going to try and get a replacement at an auto store tomorrow. Thanks again for all the help.
That is a relay. 2 of the prongs are the coil, 2 are the contacts, they will probably be normally open. There should be markings on it somewhere, the prongs 85 and 86 are the coil they should have continuity; the others are probably 30 and 87, those 2 will show open.
Hope you read this before you spend a bunch of money on a relay. It should be ok, but it's possible it's bad.
I agree with brims. The relay is probably good. If you have checked all the fuses,and you did not find a problem, then perhaps you shorted out a fusible link, or perhaps a module, depending on what you did. You can probably swap that relay with another relay on your fuse box (make sure they have the same model number), and see if that works. If it doesn't, then the relay is probably good. I would check the fuses again, and make sure they are all working before looking elsewhere.
Good call. I switched the relay out with a similar one and that wasn't it. So I spent a significant amount of time checking the manual and finally figured out which fuse it could be. To my luck, it was burned, and I just replaced it with one of the spares provided by GMC. Thanks a bunch guys. You've saved me money and time.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
