New Member, New Truck
Hey All,
I've been lurking here for a little while now and finally had the chance to get some quick pictures of my truck up for you. I traded my 07 Denali for this at the beginning of May and couldn't be happier to be back in a truck. Anyways, I picked up a CCSB Silverado with the LTZ trim and of course...the 6.2 which is just an awesome engine. So far I've had the front windows tinted and done a full de-badge. Future mods include the Bilstein leveling kit which is sitting in the garage and plans to add a custom exhaust, Line-x, and tires (those 265s have a little traction issue) in the near future.
Also for anybody who's interested, I have the Volant intake from my Denali available for $200. It was on the car for less than a year and has the PowerCore dry filter. Send me a PM and I can send photos and specifics.
Thanks for running a great forum.
good looking truck, and it's already debadged...you'll fit in well here.
edit: how much lift did your leveling kit provide? it's tough to tell you're leveled, at least from these pics.
He's not. It's sitting in his garage. Reading Comprehension > You.
:):D
:D:)
Nice truck! :D
why you little smartass :D
