Which is best recommended for tahoe/yukons? AEM, K & N and etc....? im going cold air and wanted to know from truck owners who has them in the vehicles already. thanks.
I have the GMPP cold-air kit on my truck. When the filter is due for replacement, I'm probably going to use an AEM filter. I like the GMPP and AEM filters because they are "dry"...as in they don't use oil on the filter media. This oil can foul sensors...
The best IMO
What I like about the Injen is that it does not make a lot of noise as compared to the Volant.
I've got GM's performance intake... Love it!
Can be had under $300 with a quick search.
:lol::D
Ive had several brands CAIs. I like the AEM and Volant Inatakes. Both offer dry filters now. You can hear the Air rushing through the AEM. The Volant is quiet.
just put an s and b cai on my truck. Love the look of it and the sound. My parts guy showed me the volent and the intake hole was a 1/4 the size. and the s and b was about 150 cheaper.
I went with the S&B CAI on my truck and Love it. It was a great price and the sound is very nice.
I put a K&N drop in filter on yukon denali with a MIT
Was the difference noticeable? Does the filter last as long as the stocker "HD" in my truck? Do you run the stocker box i the winter?? Is icing during the cold months an issue??
I run an Airaid MIT and a Fram Airhog Filter. The stock setup is already a CAI so your not gonna see much improvement with an aftermarket unit. I found the MIT on ebay for around 50 and the filter on Amazon for like 10. Works for me.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
