New Member, New Truck, Few Questions.
Kellie
Hi everyone,
After weeks of searching, my boyfriend and I finally picked up a new (to us) 2002 1500 HD. We drove up to get it this afternoon and I've already put 100 miles on it...I love it! We wasted about two weeks trying and failing to negotiate with our local dealer on an '01 that had been traded in. They wanted $13,900 and wouldn't budge because "it's a rare truck with low miles. It's going to fly off the lot!" Right. We got them down to $12,500, but that was still a bit much for a 9 year-old truck. About 5 minutes searching Autotrader got us the same exact truck, but a year newer, slightly higher miles, original owner, all records, leather, heated seats, and saved us $2200. So much for supporting our friendly local Chevy dealer.
Anyway, this is my first American vehicle (my boyfriend's first non-BMW), and we have a few questions. When I start the truck and my foot is on the brake, the pedal seems to jump before it sinks down - normal? I searched and couldn't find anything about it. The brakes feel fine otherwise.
There is some play in the drivers seat. It rocks back slightly when I accelerate, and rocks forward when I stop. It's very slight, but it bugs me. I searched and found some similar issues, so I take it it's common.
Thanks for any help. Here are some pics taken from the Autotrader ad.
Thanks guys. So no one has the answers to my questions? Should I post 'em in another section?
The pivot for the pedal might just need to be greased. Tell your boyfriend to take a look under the dash, its probably just sticking.
As for the seat rocking, make sure all of the mounts are tight. Look under the seat and try tightening the bolts. One of you push/pull the seat while the other one looks to see where its moving at, then go from there.
Thanks for the suggestion, but perhaps I wasn't clear about what the pedal is doing. It doesn't just stick when I go to push it down for the first time after the truck has been sitting. It actually jumps up and pushes my foot back. It does it every time I start the engine, not just intermittently. It's really weird, I've never seen anything like it, so I figured it might just be normal for these trucks, but maybe it's a problem with the booster? I think perhaps I should take this discussion to the technical forums.
The brake pedal issue is normal, don't sweat it. IIRC the HD's have a hydraulic assist brake booster, so when you start the engine the hydraulic pressure builds up and causes the pedal to change positions a little. Welcome aboard.
Welcome to the site,lots of info here.BTW,do I count 8 lugnuts on the wheels? If that the case it's a 2500(3/4t.).
What's your bf's name? He should post some too
Gramps, the 1500HDs have 3/4 ton axles.
Welcome, and I believe there may have been a bulletin on the 800 series trucks' seats.
There is/was,I just can't find it! :thumbs:
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
