Where's My Oil Going?
I've got a '01 Yukon XL with almost 94K miles on it and was 4700 miles between oil changes when I got the "check oil level" message on the DIC. I took it to the dealer for an oil change and the guy working on it only said that it could be the pcv valve acting up, but after pulling it out and shaking it, he heard the marble moving around and dismissed it as being the culprit.
He just said to check it for the next 400-500 miles and go from there.
Is there something else I should be looking at? :) I've owned the truck since new and I've never had this message appear.
Do you ever check your oil level in between changes by actually pulling the oil stick?
If not, it could have been ALMOST this low several times and you just didn't know it because the message didn't come on. :):D
It's always good practice to check the level of your oil every time you fill the truck with gas, so I'd start doing that religiously. Other than that, just keep your eyes out for any leaks or puddles indicative of leaks, and sniff your exhaust every so often to make sure you're not burning oil.
I would also suggest switching over to a high mileage oil like Valvoline Max-Life as that may or may not help as well.
I check it mainly before longer road trips, etc. but it's always been fine. I've seen some posts regarding the fixed orafice pcv valves vs. the older style like I have, should I switch it out or wait to see if the problem re-occurs?
Keep a close check on it and wait and see what happens.
Check it at least every other fillup.
So you have had the vehicle for 8 years and 94k, and its never been 1 qt low? And now its 1+ qts low? At 4,700 miles? I think GMs rule of thumb now is 1 qt every 1,500-2000 miles is "normal". Realistically, you should get between that and 5,000 miles, or more. But, regardless - check your oil!!!! It takes 2 minutes, and will save you the price of a rebuild. Unless you have drops on your driveway, or the underside is oil soaked, it is being burnt - totally normal. Checking your oil on a regular basis would provide you this history, to know for sure.
This is what I did and it worked well for me.
See Attached TSB.
Thanks much for posting the info, I'll check the hose for excessive oil post back.
Do the 05's with the alum. block have a pcv valve? I seem to get the check oil light alot more then i use to and do not see any visable leaks.
It should have the fixed orifice type from the factory. What oil are you using?
Mobil one 5-30w and usually either a wix napa gold filter or ac delco.
That's what I used and my engine would eat the stuff. I switched to Pennzoil Platinum and oil consumption dropped to almost none.
See Attached TSB.
I had a chance to get under the hood and take the pcv valve off and inspect it as well as the hose. The inside of the hose was dry but the pcv valve had quite a bit of oil inside it. Swapped it out for the one referenced in the TSB and we're good to go, hope it takes care of it. Norseman, thanks for the help and providing the TSB.
See Attached TSB.
No problem, I hope it helps.
  • 3 months later...
See Attached TSB.
Well, I changed the pcv valve out to the non orriface type but that hasn't seemed to help much - I'm at 4000K miles since the last oil change and I've checked the level since the last change off & on and have seen it slowly go down to the point where it's at the first hole on the dipstick. Nothing on the driveway, engine is clean - no blow back underneath, not seeing anything, anywhere. Exhaust is white colored on startup, and for the first few miles of driving.
I'm running regular 5w-30 - so should I stay with that or change to synthetic? With regard to the oil level drop, is it considered normal and do I just add oil between changes or is it worth trying to figure out where it's going? Thanks!
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
