Metallic Grinding Noise When Turning Left
Had the truck at the local mechanic this morning for what I thought was the front pad wear sensor making noise. He said the pads had 70% of the material left. This noise I'm hearing is intermittent and I can only describe it as a metallic scrapping sound. I have ~58K miles. It does it more frequently on left turns. I can only guess this is a wheel bearing from what I've read. I've never actually had a bad wheel bearing so I don't know what they sound like. This is a 2 wheel drive truck. How difficult are they to replace? I assume there are 2 per side? Thanks..
Well.... I had both front wheel bearings/hubs replaced this morning. $320 for the parts and $180 for labor. The noise is still there. :rolleyes::lol::cry: The mechanic is totally stumped and so am I. Maybe it's a warped rotor. The only thing left is to do a complete front brake job with new rotors and pads. Anyone have any suggestions?
Steering shaft?? A loud growl, sounds like metal to metal?? Mine does it too, and it is the steering shaft on my truck.
It's definately a metallic scrapping sound, similar to worn brakes. I think the next place to inspect is the e-brake shoes.
Check the steering shaft - go try it.
Check the steering shaft - go try it. Unless you are driving with the e-brake on, it should not growl. The steering shaft does that when you crank the wheel, mine does it too. But @ $400, it will do it for a while before I replace it.
  • 8 months later...
Check the INSIDE pads. I just posted on another thread about noise/grinding starting at 55k and I thought it was the hubs since my pads looked GREAT. Well, today I had serious grinding when applying the brakes. Pulled of the front wheels and, sure enough, the pads looked great again. Checked the inside pads this time and there was nothing left - metal to metal.
is the wheel rubbing against a brake line or something like that? could also be power steering related, think about things that are affected by turning the wheel?
Don't know if you have rear disk brakes but my 01 Tahoe started to do the same thing. Turns out the backing plates were rusting and expanding to come into contact with the rotor during certain turns. Took me a long time to figure it out but it went away permanently after I replaced the backing plates. About $30 each and you have to pull the axles to install. I also did axle seals while I was in there.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
