Horn
Anyone know where to get a aftermarket horn for a 07 HD? The one on my truck sounds like a sick animal and not very loud.
When I worked at a dealership, I had a truck come in and it had the same problem, horn sounds weak and like it belonged in a small import. Take a look at the horn and see what direction the hole is facing...think it is called the throat, not sure. If the hole is facing up, it will get full of water and other things and sound weak. To fix, remove the horn and pour out the contents (by turning it over several times), then re-attach and try it again. Should sound alot better after you do this. Just make sure that when you put it back on, you have the hole facing down.
I'll have to check the horn in my truck. The horn in my Buick is louder!
Mine was the same way, very weak sounding. I found that our trucks have a 2-tone horn system, in front of each front tire there is a horn, one of mine was not working, I replaced it and now the sound level is just fine and it sounds better, before with only one horn working, it sounded like a clown car horn.
Or carefully drill a small hole in the throat of the shell at the lowest point (as long as you don't damage or enter the diaphragm area). We always drilled a hole in the air piping going to the horn on submarines. We always had a problem with the horn filling up with water.
hornblasters.com
I love my train horn!
Heres my horn setup
Thats a sick set up you got there. I can only imagine how powerful it sounds.
I'm gonna do that public address set up. They are pretty loud and sound really cool! I had the wolo triple trumpet horn, was a real cheap product made out of plastic and the hoses always popped out on me. I liked the air horn sound much better then boring stock horns. I have a public address on my CB Radio that I had onced hooked up on one of my prior trucks, but wasn't that loud cause CB output was lame. With my Alpine head unit, I can now run it into that, then out to external speaker and have power now with public address, haven't tried it yet though. The head unit has Aux in's, so it would work. But I don't have any special sounds with it.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
