2003 Battery Drain Recall for certain models
#02066 -- Battery Drain
involved vehicles are certain:
2003 Chevrolet Silverado, Tahoe, Suburban; 2003 GMC Sierra, Yukon, Yukon XL; 2003 Cadillac Escalade, Escalade EXT, Escalade ESV
Equipped with Quadrasteer (NYS), Autoride (Z55), or Vehicle Stability Enhancement/StabiliTrak (JL4)
December, 2002
Dear General Motors Customer:
We want your experience owning your 2003 model year Chevrolet Silverado, Tahoe, and Suburban; 2003 model year GMC Sierra, Yukon, and Yukon XL; and 2003 model year Cadillac Escalade, Escalade EXT, and Escalade ESV vehicles equipped with Quadrasteer, Autoride, or Vehicle Stability Enhancement/StabiliTrack to be better than any other you've had ... which is why we're writing.
We have learned that your 2003 model year Chevrolet Silverado, Tahoe, and Suburban; 2003 model year GMC Sierra, Yukon, and Yukon XL; and 2003 model year Cadillac Escalade, Escalade EXT, and Escalade ESV vehicle may have the potential of exhibiting a battery drain condition. An anomaly in the operation of the steering wheel position sensor may keep the Body Control Module (BCM) from shutting down when the key is in the OFF position. The resultant 3.5 amp draw/load on the battery could possible discharge the battery to the point where the battery will not have sufficient amperage to start the vehicle.
What We Have Done
We've sent a new BCM calibration to your dealer so that your vehicle can be reprogrammed to ensure that the BCM shuts down when you turn the vehicle off. This service will be performed for you at no charge.
What You Should Do
We recommend that you contact your dealer to arrange a service date. If you have experienced this condition in the past and your battery was recharged or replaced, your vehicle will still need to be reprogrammed.
here are the VIN breakpoints to determine if your vehicle is possibly involved (contact your dealer or the customer assistance certain to determine for sure):
Plant: Flint
Through: 3F165707
Plant: Oshawa
Through: 31235800
2003 Chevrolet Tahoe
Plant: Arlington
Through: 3R181251
Plant: Janesville
Through: 3J179899
2003 Chevrolet Suburban
Plant: Arlington
Thtough: 3R181251
Plant: Janesville
Through: 3J183738
Plant: Silao
Through: 3G183738
2003 GMC Sierra
Plant: Flint
Through: 3F165315
Plant: Oshawa
Through: 31235792
2003 GMC Yukon
Plant: Arlington
Through: 3R181273
Plant: Janesville
Through: 3J179886
2003 GMC Yukon XL
Plant: Arlington
Through: 3R181273
Plant: Janesville
Through: 3J179886
Plant: Silao
Through: 3G183779
Plant: Arlington
Through: 3R181357
2003 Cadillac Escalade EXT
Plant: Arlington
Through: 3G183821
2003 Cadillac Escalade ESV
Plant: Arlington
Through: 3G183821
  • 6 years later...
I realize this is a very old post, but......
I am wondering if this BCM re-calibration is available other than from a dealer? Has anyone had this re-calibration done? My truck (2003 1500HD) is not within the VIN range listed in the bulletin but seems to have parasitic draw that will nearly kill an Optima red-top overnight. I know, I know...the curse-ed Optima. So I charged up the OEM Delco and put it in and exchanged the red-top for another one.
The OEM battery has been doing a fine job since Saturday Jan. 17, 2009. Now I detect that each day it is a little more sluggish but has yet to fail to start the truck. I am going to use a battery disconnect switch to try to track down the drain.
Any advice, insight, or revelation will be greatly appreciated.
Best regards,
Jeff P.
  • 2 months later...
I have a 2003 Silverado Z71, it has had this problem. Called 3 Chevy dealers, they deny that any problem of this nature exists. I have replaced the battery twice and two new alternators installed. I find that I still have a 3.5 amp draw even with alternator cable disconnected.
Again, the dealer denies that there is any existing or documented issue regarding parasitic draw on these vehicles. They recommend I bring it in and pay a minimum $100 fee just to start testing with no guarantee they will isolate the problem within a reasonable amount of time.
I would print out a copy of the above, hand it to them and say; "What's this?"
If they still deny it, I would then call GM and ask what you should do...
Do you own a voltmeter? You could do a drain test to figure out which circuit is drawing too much power.
if that recall does not apply to you truck , the tech 2 will not let you program it . i would tell you to look for your amp draw somewhere else . sart pulling fuses .
I have pulled fuses for two days. The problem is intermittent. The dealerships will now aknowledge that they discovered an issue in 2002 but refuse to do anything about it since I am now "out of warrantee." I asked them to please perform the reprogramming that is refered to in the document but they are asking for $125 diagnostic fee.
Tvango,
I have been having some of the same fun as you I think. I have an 03 2500HD 6.0 auto that about 2 weeks ago would be fine until the first start of the morning. I would have to jump start it. Once going, all would be fine. I have replaced the battery and cleaned the battery terminals including the alternator ground terminal. I had the guy at Advanced check the alt out and all looks good to him.
As for the intermittence of your issue, have you charged the battery back up to full charge? Sounds odd and like a stupid question but the alternator may be showing a good charge (on dash) and may be doing enough to run the truck, but not enough to charge the battery full. I thought I have an good day/bad day issue going with being intermittent also. I am on full charge today so far, I will see tomorrow what it will bring.
For the suggestion of using a volt meter to do a draw check... I am not sure how to do this without the ability to check DC amps. If someone could explain that, maybe the clouds will lift for me on that one. My meters are primarily for HVAC/home applications not for automotive. I can do DC volts but not sure how/where to measure. At the fuse block itself?
Good luck and maybe I will get some issues relsoved also.
Chupe442
