First oil change on 5.3L ???????
Well hit the 1000 mile mark and got to do the first oil change on the truck. Removed the oil pan drain plug and started letting it drain. Went in an got all my various filter sockets (None fit of course) slid the strap wrench on and began loosenng the oil filter and hey oil is dripping down the filter. Okay no biggie started loosening more and oil is gushing down the filter "freakin A". Spin it off and oil is gushing down out of the port where the threads are?? I would guess about a quart came out while taking the filter off, is this normal for a 5.3? I have done lots of changes but never had a vertical filter do this, what a mess. Plus I learned even though the exhaust is cool the catalytic converters stay very hot. :D If this is the way every oil change is going to be I will have to cut some heavy plastic to keep the oil from running into the skid plate. Let me know if there is a trick or something to oil changing this motor. Thank you. :D
Hey tryn2lrn,
I too created a giant oil mess during my first 5.3L oil change. Used to my Subaru Legacy where I can reach under the bumper to spin off the filter and plug.
My fiasco started out with a 3 foot stream of oil towards the rear of the truck. I was expecting a 1 foot stream. Then the killer was the 6 inch stream towards the FRONT of the truck when it dribbled down the edge of the hole. :D Okay, so this was my first rear-facing plug. I put in a Fram Suredrain (SD-4) to see if I I won't make the same mess twice. :D
I decided not to take any chances with the filter. I took a 3 inch nail and whacked it into the bottom of the filter. This created a beautiful controlled stream of oil into the drain bucket. While that drained, I cleaned up the oil slick on my floor.
Filter should be easy after that, right? Holy #$&@! was that factory filter on TIGHT! :cry: Had to cram a screwdriver in the side to crank it. The molded drain pan sure doesn't make it easy to stick a filter wrench on there. Well, at least it didn't make a mess - nice and clean.
So I think the next time I change the oil, I will start with my handy drain coupler. Hope that thing works as well as it says it will - never used one before. And I will continue to punch a hole in the bottom of the filter before taking it off. If you punch the hole far enough back, it will clear the skid plate.
Not sure if this helps you. But I feel your pain, man. :puke:
Same problem here - LOL, when I first changed the oil I think half of it was mopped up off the garage floor. Never thought the oil would shoot that far back. And yes, there's A LOT of oil that'll come out when you take out the filter.
Supurban makes an excellent suggestion using the nail.
Other annoyance factor: as the oil flow slows, it starts dripping all over the skid plate and then leaks out the holes in the plate. :D
My current plan is to trim the excess off the skid plate with a grinder so that way the oil drains directly into the pan. If you want a dumb idea, try a laundry detergent bottle. Cut the bottom out of it and cut one side to form an angle - think like a splash shield. Then use it to direct the oil flow when it comes gushing out. I guess the worst part for me is that I change my oil in my dad's garage (I live in an apt., and I doubt they'd like me doing this in the lot) - and my dad's never thrilled with oil on the floor. So I use LOTS of newspaper and rags to keep the floor clean.
My F250's filter does the same thing. I loosen the filter with a wrench enough that I can spin it by hand then hold a small garbage bag up around the top of the filter to catch the oil and filter when it comes off. Can't remember if this is possible with the GM 1500s now. Last oil change I didn't spill a drop on the ground when I changed the oil/filter.
Welcome to the first 5.3 oil change club.
Takes basically two pans to drain these trucks without much mess.
One a elongated for the "two feet" pour from the drain plug.
Another for the oil filter, first punch a hole in the filter to drain then remove.
You guys haven't had the joy of changing the 6.0 yet?
Let me tell ya' that's great fun with the two foot stream that you talk about splashing directly on the exhaust y-pipe crossover!! :D
You guys need to add a challenge to your life - even with a huge tranny drain pan there are still little dots ALL OVER my very clean bay.
:puke:
Take the challenge and do a service for a buddy with a 6.0!! :D
LMAO...I'm glad I'm not the only one. When I changed the oil the first time in my 5.3 I had the same experience. I crack the drain plug loose, estimate where the oil will likely drain to, line up the drain pan and then remove the plug completely. I totally overshot my pan and oil was all over the driveway. I was like "WTF--does Chevy pressurize the oiling system when this thing's not running??" I didn't have the problem with the filter, though. Most of the oil that spilled from the filter area was when I was trying to lower the filter down and I bumped into the exhaust and oil spilled out of the filter.
You cannot change filter on my 2000 K3500 without getting it on front diff and pinion slinger. Just comes with the territory these days.
i have had some luck pulling my truck onto some ramps when changing the oil. the added height changes the angle of the truck enough so that the drip of oil misses the skid plate.
:D
Thats how I do it...... I pull it up on a set of ramps, and everything works fine... just take your time un-doing the oil filter, and have that pan ready...
The biggest problem I have is getting that one little grease zerk on the passenger side...
The tip I have on my grease gun isn't small enough.... I need a 90 degree fitting on my gun to get to it...
JimG, you've got a great idea with that laundry detergent bottle. But like GuyZ71 pointed out, the way the oil shoots out, I might stick a brick behind the bottle to keep it from tipping over! :D
My first oil change with the 4.8 went the same way.
Before I even start, I make sure the filter is loose. If I cant turn the darn thing, I know im in trouble mess wise...
If I can get past that hurdle the rest is easy. I do like the nail idea. I going to do that one from not on... :D:D
    • I prefer new, but not without a deal. Historically I've bought severely aged new inventory, leftover model year, unpopular configuration kind of stuff that sits around on dealer lots until they just want it gone. $10k off MSRP kind of stuff on a mid-priced truck. That really, really helps knock down that first year depreciation. It also requires being somewhat flexible on colors and options. I wouldn't buy a 4 cylinder if I was looking for an 8 cylinder, but if I got blue paint instead of black, or a great deal was lacking a minor option, I'm willing to overlook those things for savings.   Used <> used. Condition and history are everything. If I'm buying used I'm looking for cream of the crop. The truck from the guy who religiously pampers it, and then decides a year later he wants newer and nicer. NOT the ex-rental vehicle, or the crew cab traded in by the family with 7 kids who like to throw food, and the oil only got changed when there was time long after the oil life monitor started alerting.
    • @Grumpy Bear the conclusion from your post about doubling engine life has me curious. Are we literally talking an expected life of 250,000 miles potentially becomes 500,000 miles with a step up in filtration for fresh oil at "the oil factory" when it's bottled? I know you said that's a single variable among many, but, that's significant if the implication extends that far into a real world use case. I would think the oil marketing folks would really eat that up and make it known.   Particles introduced during oil change is a fairly easy one to avoid, but probably not intuitive as one would think. I.e. using a clean funnel. But...what was it wiped with? Paper towel leaves behind little fibers. A solvent if not dried is not something one would want to introduce into their engine with clean oil. And, keeping the oil filler neck clean and free of buildup.. Look at some guys engine bays and they're an absolute mess. Some say that's better than the drawbacks of cleaning it. I'm not a buyer of that idea.   I've also wondered if "flooding" the top end of the engine with oil while filling is a bad idea. During normal lubrication the oil flows in a gutter back into the galleys. But if you flood the area you're potentially washing the top of the rockers, springs, and other areas which may not get much oil wash normally, and you're mixing all that into the new oil. I just don't have the patience to pour slowly. 😆
    • It was a bad pump, i had a dealer next day the pump. Gm part #86591535. Tools needed 10mm socket, pliers for hose clamps, 1/2gal of Dexcool. About 30mins to remove and install, pump located near oil filter on driver's side frame rail. I had a local mobile mechanic delete the code, he had a snap on scan tool. My scanner could not delete the code. I drove back home about 700 miles since then, and no check engine light. Hope this helps someone in the future in the same situation i was in. Thank you to all that helped me.
    • Hi Gary, I guess it all boils down to personal preference and what you can afford. I, personally, buy new because I will know from day one how the vehicle is maintained and driven.
