Rear differential gasket newer models
Found some discussions across the Web about how some rear differential cover gaskets are lacking needed openings that may result in bearing failure.
Not sure if this is true or not but it may be a good idea to be aware of the possibility.
Appears the "good" gasket, the one from GM has a part number of 26066456
Here is a pic from another site showing the good gasket atop the bad style lacking the cut-outs:
http://scican.net/%7Ejbpalmer/Impala/gmfel.jpg
A small amount of info is here... scroll down to view:
http://scican.net/~jbpalmer/Impala/
I am unsure of when changes were made in the GM axle requiring the newer gasket. One message board thread told of early bearing failures and a mechanic mentioned their shop had come across several of these failures and had reported it to GM but GM took no steps to inform the public about the need for the new-style gasket.
My info is sketchy and not backed by personal experience but felt this info should be passed along. It may have already been covered here but my on-site search did not find the discussion.
I visit several GM and Checy truck message boards but have not seen this topic posted at any of them. I will post it here only and, if you believe it should be spread around, feel free to post the info elsewhere.
Thanks!!!!
looks like an aftermarket gasket was poorly designed. This is mostly a non-issue for 99+ GM trucks due the drain plug allowing fluid changes with out molesting the gasket.
My '04 1500 does not have a drain plug and GM stopped putting them in sometime in either the 2000 or '01 model year,why I have no idea,probably cost reasons,all I know is that now its a pain in the butt to change the fluid compared with my '99 I had. :thumbs:
i just changed my gasket on 1998.no drain plug. MAKE sure you have the right socket to take of the boltsf.dont use those ones with the many sides,use one with 5 side type.if you screw the bolt head up, oh my. those bolts on mine were rusted in badly.i put compound on them now to get out easier next time.they were very tough to remove.i bought a gm gasket for 3 dollars at chevy garage.there are 2 gaskets for that year too.1 is much bigger.take care :thumbs:
Perfect timing for this thread!
The big brown truck showed up this week with my TA Performance aluminum rear differential cover/girdle. Hoping to find the time to install it soon. It came with it's own gasket, plus I have a GM gasket that I bought a little over a year and a half ago when I changed my diff fluid. My rear has drain and fill plugs, so I didn't use the gasket but hung on to it. I want to compare the gasket that came with the cover to the GM one (after I check the part# on it) and see how they differ. Unfortunately my GM one is in my mother's garage and not here or I'd check it right now.
:thumbs::):)
i just changed my gasket on 1998.no drain plug. there are 2 gaskets for that year too.1 is much bigger.take care :thumbs:
Yes,on some of the old body style 1500 trucks you could get a "Heavy Duty" chassis pkg. (RPO Code F44) that gave you a 9 1/2 inch rear end,11.15x2.75 rear brake shoes,bigger u-joints and an additional leaf spring (basically it was a light duty 2500 rear end)it increased the GVWR from 6200 lbs. to 6600 lbs.
That is where the different size gasket comes into place,my '94 and '97 had the F44 option and there was no gasket from the factory I had to use sealer.
And I forgot that the 2500HD's still have a drain plug! :)
I also have an '04 1500 without a drain plug. I can't see why that made sense to them. $$ I guess. Anyway, I have a 10 bolt rear and was just wondering if this part number 26066456 is the right one for my truck. Can someone please verify this?? Thank you.
i just changed my gasket on 1998.no drain plug. there are 2 gaskets for that year too.1 is much bigger.take care :D
And I forgot that the 2500HD's still have a drain plug! :D
That's odd - After reading this thread I went and looked at the rear diferential on my '02 Suburban, as it's due for a fluid change. There appears to be a drain on the bottom of the differential (I'm assuming that's what the 3/8" square drive plug on the bottom is).
My '04 1500 does not have a drain plug and GM stopped putting them in sometime in either the 2000 or '01 model year,why I have no idea,probably cost reasons,all I know is that now its a pain in the butt to change the fluid compared with my '99 I had. :D
No differential drain plug on my '06 Z71 either :D
Just how much money do these people save by eliminating one drain plug? My '95 Nissan turck had a fill and drain plug on both differentials, on the manual transmission, and the transfer case.
  • 4 years later...
Turning and cornering can cause a vehicle to turn over. Vehicles remain stable because of the use of differential. All vehicles should have this.
:rolleyes:
The presence or the lack of a rear drain plug is due to who manufactured the housing and what assembly plant built the truck. I have never seen a drain plug in my last 5 trucks that were all built in Oshawa Canada. Not all the rear's are cast in the same place. A few years back when AAM when on strike in Mich, plants in other countries were sourced. I recall a service message that explained certain oddities from the one made in France.
Fwiw - My 2010 has the fill plug on the rear cover.
You should always use a gasket on the rear cover. They are designed to seal with a gasket. Problems with silicone or RTV seal is they often leak due to improper use. The product needs to cure a certain amount before installing cover and then before installing lubricant. Also some synthetic lubricants can cause a chemical reaction with the sealer so you need to buy the correct stuff. Also, it may not start to leak right away but gradually over time.
Put on the gasket, if done right, its fool proof and you fill the lube and drive it right away.
dude, your first post was to a 4+ year old topic, and you drive a dodge? and your post is odd. Actually, it doesn't make sense.
    • It really doesn’t matter to me. Making a blanket statement that can be refuted will be. As I pointed out the information is out there. Hey google.
    • My area is one of the most affluent areas in Texas. And yet affordable housing is close by. My family business pays top wages and turnover is very low. You can’t but people in a box if you want to succeed the opportunity is there.
    • It was previously working, but the continually running compressor threw me for a loop. It wouldn't be out of the realm of possibility that a 26 year old AC system had lost some of its charge and could be exhibiting low charge indicators, so I thought I had it licked. Add some refrigerant to get the low and high pressures in range like on the old 134 systems.   I learned the continuously running compressor is normal, and that I need to know how much is in the system, as well as needing to meter what goes in. I'm only used to working on older R134a and R12 systems that aren't variable displacement. This is how we learn...LOL.   Long story short, I had a 20% off coupon for a new Jiffy Lube that opened nearby. I took it up there yesterday and they did an evac/recharge using their brand new machine from Mahle. Had a good conversation with the guy, they loved the car and I was out of there for $159 plus tax. Digitally measured charge, exactly 1.5lb of refrigerant went in.
    • In most areas of the country, wages have trailed CPI increases over time (let's say, since the 70's) and things like housing, energy, and food have vastly outpaced wages on the whole. Can't ignore that, it's very real.   That isn't to say there aren't ways to live in ways that mitigate some of that, including moving to cheaper areas of the country. In KNut's neck of the world, median housing prices in "nearby" Dallas are more like $500k. If you're raising a family and young in a successful career, your economic opportunities are probably going to be better living closer to Dallas than Cornhole. A 3 hour (6+ round trip) daily commute probably isn't tolerable for most folks. Grumpy mentioned economic migration; but we've seen what happens when people populate and grow an area. It becomes more expensive when economic opportunities come to roost.   One thing different now from back in the 70's is our quality and standard of living has changed. Healthcare is light years better, for example. But it's also much more expensive. And we have communication and information/tech tools that folks in the 70's could never imagine, and they're accessible to people of just about all incomes. Cars are light years safer, faster, and filled with tech advances. Homes are larger, more energy-efficient, and more luxurious on the whole, from starter homes to luxury homes.   Seattle was once affordable. My folks came here in the 70's with a lot of other people from California looking to escape uncontrolled sprawl, smog, and rising prices in the Bay Area. Seattle and the surrounding area has grown considerably; The home they bought for, I think it was $70k or $80k in the late 70's is now worth $1.2M today. The same house.   So while there have been obvious boosts in some areas of quality and standard of living, regarding opportunity, that's a bit more nuanced. It's really not possible for young people to get started in similar situations in areas of the country that have become "HCOL" (high cost of living). There are many more areas than before, which is to say they exclude younger workers or make their lives significantly harder. They have to commute farther and longer to afford to live in the area. They have to take outsized risk, take on more debt, significantly delay family planning. Or, they could move somewhere cheaper, but there's usually a loss of economic opportunity that comes with that. Even for the same job, it may pay a lot less in a LCOL.   What I don't like are Boomers with phones thinking they have all the answers and outright saying that if people stopped paying for their cell phone that they'd be rich. It's as stupid and misguided as people who think they'd only be rich if taxes weren't so high. Sorry guys, Elon proved you wrong on that one, I guess you're just lazy and blaming your own situation for the reason you're not wealthy. Mobile communication is basically an expectation in a modern society and workforce and it's often cheaper than having a copper landline these days, so... What's your point?
    • My 2008 started exhibiting similar symptoms, wasn't 'cold' enough. I went through a pretty extensive diagnostic process for a DIY'er with limited OBD access. System evacuation and recharge included.   Noticed one day the passenger side was cold (I'm never over there so took awhile to notice).   Pulled the drivers side blend door actuator out, disassembled it and cleaned it out. Put it back in and did some kind of reset and it fixed the problem.   Long story short, it wasn't the A/C system at fault, the blend door wasn't moving to full cold position.
