Adjusted Bumper Tonight On 08 Sierra
Since picking up my truck last week there has been something that my eye keep getting drawn to. the front bumper alignment where it meets the tire. THere was a gap at least 1/2 larger then the rest of the gap where it meets the upper bumper plastic. it was driving me nuts. looked like the truck was in a front end crash. i was able to raise it at least 1/2 on each corner. very simple too.
just had to loosen 3 bolts push the bumper up and tighten the 3 bolt back down. would have been easier if i has another person to hold the bumper up. i just jammed a couple pieces of wood there to hold it. i attached 2 pics of the bolt that have to be loosened. the bolt in the second pic is behind the wire loom for the fog light but if you look under your truck its pretty easy to see what bolts have to be loosened. its the tubular bracket that holds the side of the bumper up.
now i can continue to look at the beauty of the truck without getting ill.
Did you have before/after pics of the sheetmetal on the outside?
Also. I assume you are talking about the gap where the chrome meets the painted plastic filler on the sides?
Or is it were the the two sides have a tight fit and the center of the bumper and the plastic piece has a bigger gap?
yes the gap between the chrome and painted part. it was only out at the ends where the bumper ends and the wheel well is.
i dont have a before pic. i should have snapped one. here is an after pic. it was dark when i finished.
crepitus,
So...did you have an oil leak...or what did you smell burning??
How do you like the 08 so far??
i do really love the truck. put 160 miles on it today. first time i spent alot of time in the driver seat on the highway. the ride is far better then my old truck. the afm is a bit annoying. it seems that when it kicks in the trucks seems to slow down. i already contacted black bear about a tune. had one on my last truck and it was a night and day difference.
2 more things i have to fix that are annoying me. i still do have a oil smell coming from the truck. very noticable at stop signs and when i back out. not burning oil but like a vent that is not hooked up. i can not smell it when just running in the driveway. i have been under the trck and no luck. the other thing is the driver door makes a rubbing sound at the top corner where it meets the back door (extended cab). when i push on the top of the door it seems to go away. havent figured that one out yet.
have some mods coming too. just got the gm bed rail caps and the molded carpeted floor mats. my husky mud flaps should be here next week. the 20" tires really throw alot of stuff up the side of the truck. pics of all the mods to come once they are all installed.
...the other thing is the driver door makes a rubbing sound at the top corner where it meets the back door (extended cab). when i push on the top of the door it seems to go away. havent figured that one out yet.
I haven't noticed the rubbing sound...yet...but that's one thing I hate about the Ext. cabs with the "suicide doors"..they never seem to be aligned right. The 02 S-10 I traded in on my Sierra had the door squeak as did the 2000 Silverado I had years ago. On the 08, I don't get that "solid" door closing thud...it looks, feels, and sounds like it's a tit out of adjustment. Or maybe that's just the nature of the beast with this design?
Every excab with the center meeting doors sounds like that to me. The rear door doesn't make for a solid surface to close the front door against I guess. So far I don't think anybody is having problems with it. You might need an adjustment for the creaking sound though...
exactly. mine does not sound like its making a solid closing sound either. maybe it is just the nature of it. my last 06 didnt have any problems of making nosies around the door.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 0 Anonymous, 721 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
