I purchased my 2008 Sierra used and only got one key and key fob. I bought another key and fob but when I got the key cut it won't work. I re programed the fob and that works fine but the key will not start the truck. Does the original key have a chip? it doesn't look like it does but if I hold the original key next to the steering column the truck will start for a second then shut down?
Use the original key and start the engine, then stop the engine and remove the key. Insert the new key and start the truck.
+1 ^^^ What he said! ^^^
no, but those new keys are "precision" cut as described to me by my local Cothron's. Have no idea if there is any truth to this but every key that I have gotten done has worked but not from Walmart, Home Depot, Lowes or any other store....
Maybe their key cutting machines are worn out? Or the cutting blade at least.
My understanding is that my 08 truck has a chipped key (it does indeed have a + sign on it) and is programmed by going thru the sequence described above (start with orig, remove, start with ne key). I bought two new GM blanks and have yet to have them cut.
Yep,Actually all '07-up GMT900 trucks have the resistor key.
Thought the resistor was in passlock 2 or something and the 900s have passlock 3+.
This is a very informative thread. I need to check the key I bought a while back and stored it in the bed as a backup to see if it will even start the truck, my truck is an 05. Can I ask, when you wrote "but if I hold the original key next to the steering column the truck will start for a second then shut down?" Do you mean in the literal sense just holding it next to the column it will start? Thanks in advance, Jake.
Your truck doesn't have a resistor or transponder key,Its only the '07-up GMT900 trucks.
My 99 GMT800 doesn't have a transponder key. I've bought spare keys while on long hunt trips in the middle of nowhere South Dakota (Huron) and they were plain keys. I've cut the plastic completely off a key for a wallet spare and it works.
