Seat Bolts
Trying to put a new seat frame in my 04, got the new frame (some of the wire support snapped on my current one during drive from Phoenix to DC). Does anybody know what tool is used to get the bolts off that hold the seat down? Or what the bolts are called? It's like some star shaped thing.
much obliged. Apparently a coupe of 12 point sockets will work on them also.
what sizes? I may need to run with one deep socket for the front passenger side bolt (nearest the passenger door in the front of the seat since my E20 socket does not quite reach)
Looks like a deep socket will indeed be required for the front bolt. 11mm and 15mm according to 05quadrasteer (I think the 15 is for the front).
I have a special socket from Mac Tools for the nuts at the front of the seat rails. I remember trying e torx, 12 point, 6 point, etc., and nothing worked. I asked the Mac guy and he told me about this socket. Sure has come in handy over the past few years.
http://www.mactools.com/product/tabid/120/...993-sc620b.aspx
Did it work for the front passenger side bolt that looks like it will need a deep socket? Reason I ask is because I took off the seats prior and they didnt seem as hard. I know that the dealership removed the passenger seat due to them replacing the passenger airbag sensor under the seat...I guess they overtorqued the bolts.
I had my seat out today to replace that frame/spring assembly (thank god I have manual seats, removing all those little motors would have been hell). Didn't take me too terribly long. I used a six point 15mm deep socket on the front nuts and a six point 11 mm deep on the rear bolts. Those sockets worked fine. As an aside, this frame/spring unit (88943143) is like 115.00 (including shipping) on gmpartsdirect.com My local dealer (I needed this pronto) told me 180.00. I told him "that's high as a kite, I'm not paying that" Then he said, "well, we're giving it to the shops for $135.00" I said "fine, that's a little better." Still more expensive than GMPD, but gosh, that extra $45.00 would have been total gravy for those guys (because it's not like at even 135.00 they're selling it anywhere near cost).
It works on all four nuts which hold down the front of the seat tracks.
  • 4 years later...
I hope it's not too late to reply to this topic. I have a 2006 GMC Sierra 1500 Crew Cab, and the manual seat adjuster (forward and backward) is broken. The handle just "flops" up and down. I'm having trouble getting the seat out. I used a 15 mm deep 6 pt socket OK on the front two bolts, but the back ones have me a little baffled. The inboard one is easily visible, but I can't even get my 1/4" drive and 11 mm socket squarely on it. The head of the ratchet is preventing it. Am I missing something?
The outboard one I don't even see. I have managed to get the seat all the way forward, but still don't see it. Advice?
What are the wires under the seat for? I don't have seat heaters (at least that I'm aware of). They seem to connect to something that is attached to some sort of plate that runs front to back along the inboard side of the seat track. It looks like some kind of sensor or ??? I bought the truck used, so I may not be aware of some features on it.
Thanks in advance.
You'll have plugs for the seat belt buckle and for the seat position sensor. It sounds like you're using the wrong type of sockets to remove the bolts. You'll want to get the inverted torx or whatever they're called for installation so you can be sure they're tight.
Thanks for the reply and info about the electrical connectors. I know about the inverted torx nuts on the seat bolts, but I've read on several other forums that you can use a 15 mm deep socket on the front ones (and I did) and use an 11 mm deep socket on the rear bolts. My problem was locating the rear outboard bolt. I think I found it from some pics on another forum, but haven't had time to go try it yet. Thanks again for the response.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
