How-To: Add Console and Leather GMT800 Pickup.
I recently purchased a 04 Silverado with a manual transfer case and the 40/20/40 bench in cloth. I wanted a center console and leather captains chairs. The manual shifter presented a problem, but I was able to get the console in and still have access to the shifter. Below are some pics and the steps you need to follow, to get the job done.
p.s. If you want to keep the Bose sub and amp, stop reading, its not possible.
Tools Needed – 9/32, 11mm and 5/8 sockets, Phillips head screw driver, jig saw
Remove the trim around the gauge cluster (comes right off, just pull straight out). Remove the glove box and the trim under the steering wheel. Remove the old seats
The new console will need to be completely disassembled so you can remove the air ducts (if it has the rear air vents), the Bose sub and the amp.
Cut the console like the picture below. You will need to cut and test fit to make sure you can put the truck in 4 high and low. If it hits the console, take it back out and cut some more. After the case clears the shifter, you can put it in place and start working on the plastic trim.
Cut the outside plastic like the picture below. Cut and test, cut and test, cut and test. Once you get close, attach the outside plastic piece to the case and test fit some more.
After the case and outside plastic clear the shifter, reassemble the console and install. Don't forget to plug in the 12v outlets from the dash. Don't ask how I found this out….haha
Before you secure the console to the dash, make sure to put the new glove box assembly in.
Secure the console to the dash.
Install the seats.
Hopefully this write up will help. If anyone has any questions, please let me know. :lol:
  • 1 month later...
very nice, I've been thinking about doing this for a long time.
Then it just popped into my head, what about the 4WD.
Does the air on the console even work?
I know it has the cover down there behind the dash trim which can of course be removed.
But is there anything back there to connect the air to?
You said remove air, but do they go back in? or did you have to leave it out for the shifter?
Not that I much care, I'm in the front seat lol
_______________________
How easy is it to shift? Looks like a bit of a hard angle to get at it
-Kenny
The air to the back seats does not work. I had to be removed for the shifter. I'm sure it could be mod'ed and installed, but like you said, I don't sit in the back.
Its actually pretty easy to shift....I still need to put some back trim around the edge of the cut out. Kinda dress it up a bit.
Cool, now I just have to find one cheap for a tan interior, which don't seem to be too common.
Is the shifter comletely under the console or does some of still stick out so you can get ur hand on the top?
It's hard to tell from the pic.
Maybe if you get a sec. you could add a pic from above? :lol:
  • 1 month later...
Did you have to change the glove box trim panel or just use the one that was in there originally ... The reason I ask is I just bought a console and am looking for the glove box dash trim panel that it mounts to
Install the seats.
Did you have to replace that glove box trim panel with the one that goes with the floor console OR did you use the one that originally came in the truck
  • 11 months later...
Do You think i might be able to do this in my 2001 gmc 2500Hd sierra it also has the manual trans case and the 40/20/40, im just wondering because of the dash is different.
ok guys, someone hurry up and try this on a GMT-900. I'm am dying to put a consloe in my truck with manual transfer case......
Good work. Thanks for posting!
  • 5 years later...
Tools Needed 9/32, 11mm and 5/8 sockets, Phillips head screw driver, jig saw
After the case and outside plastic clear the shifter, reassemble the console and install. Don't forget to plug in the 12v outlets from the dash. Don't ask how I found this out.haha
Install the seats.
Hopefully this write up will help. If anyone has any questions, please let me know. http://www.gm-trucks.com/forums/public/style_emoticons/#EMO_DIR#/cool.png
I can't see the pictures you posted?
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
    • Or put you in a lawn chair on the curb, with a free sign.
    • Still $4.50 85 oct.
