Seafoam
everyone in here has been very very helpful, Im just curious were to find this SEAFOAM product, and just want to know how it works exactlly. It seems like alot of people use it. and it has done its job. thanks
It is sold only in the northern states, not sure why. Heres the link. If you go to your local walmart and tell them to order it they will, you might need to buy a case though. I am not a fan of it in the fuel system, I have seen to may carburetors gummed up that had sea foam in it, there was like a rubber cement in the bowls and was a pain in the A** to clean. If your looking for a carburetor/injector cleaner or the top end/carbon cleaner buy Amsoil Power foam, you spray in through your intake when the motor is hot and then let it sit for a half hour before restarting it. I also spray in into my gas tank, 1/2 can on a car and full can in my truck, that cleans 100% of your fuel system,valves,rings and top of piston. If you have a OMC boat dealership around, they have a product called engine tuner, this has been around longer than the Amsoil product and has been very well known. If your really stuck on sea foam let me know, I can ship you a bottle or more out of my store. I even stock a can for the crazy ppl that love it. Hope this helps.
www.seafoamsales.com
Hmmmm I guess Texas must be a northern state now? I can buy it anywhere here. :)
Hmmmm...
I can get it in Northern Atlanta.
Always have it:
Auto Zone
Advanced Auto
50 50 chance:
WalMart
I have a mechanic friend very much in the know with GMs. He said SeaFoam is basically the same recipe as GMs upper engine clean BEFORE they removed all the carcinogens. And SeaFoam is a third/quarter the cost. The longer you let the seafoam sit the better. Last time I did the truck I let it sit for an hour. Drove the truck for five miles before all the crap was out.
California too.
Best results from it and another one we have used is down the brake master vacuum line. Works great this way. I have never tried it in the fuel, or the oil. Both counts, I am a little hesitant.
I look foward to using it, MY other question is. After i use the seafoam i have to change the oil but what about the plugs. will they be ok. Also has anyone tried it in all 3 places , Intake, Oil, Gas tank??
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
