09 2500hd Vs 1500
Other than the increase towing and hauling capacity what are the differences between a 2500 and a 1500? I have an 07 1500 4.8 4x2 silverado long bed wt and the ride is awful. Can a 2500 get much worse? I am considering upgrading to a new 2500 ext cab long bed 4x4 6.0 and wanted to get some feedback from people that have them.
The 2500 is going to have 'truck' tires, while your 1500 may have P-rated tires. Hence in most cases, a softer ride.
If you feel the ride in your 1500 is rough, I don't see you liking the ride in a 2500.
I agree I went from an 07 1500 CC 5.3 to an 09 2500HD CC 6.0. It rides like a truck but if you need a 2500 with the increased load capacity and towing stability then that is what your gonna get. Surprisingly I have found at 65-70 unloaded it is a pretty smooth ride, I air my tires down a bit when not towing.
Has the ride on the new body style gmt900 trucks been improved at all with the redesign? I'm glad you brought up tires, I did notice all the 2500 trucks look like they have tires on them that are too small for the size of the truck. I see that as one of the first things to upgrade to something larger.
A 1500 is for somebody that DOESN"T do alot of heavy towing or hauling. If you do it only once in a great while then stick to the 1500. On the other hand if you do even a moderate amount of towing then go with the 2500HD. Either way neither truck will not ride like a passenger car it will ride like a truck. If you want to improve the ride of the 1500 you might look at a set of airbags or a better set of shocks but that won't improve it to much. Just my opinion.
...or go drive a pickup from the 70s and then drive one of the new ones and you'll really appreciate what they've done with them. :lol:
But like it's been said if you don't like the ride of a 1500 I wouldn't suggest you getting a 2500.
...or go drive a pickup from the 70s and then drive one of the new ones and you'll really appreciate what they've done with them. :D
I agree on all counts!!
Holy crud :eek:... The ride from the GMT-800s to the GMT-900s are vastly improved in the 1500's. The 2500's still have torsion bars :D
Night and day from my 03 (gmt-800) to the 07 (gmt-900).
Holy crud :eek: ... The ride from the GMT-800s to the GMT-900s are vastly improved in the 1500's. The 2500's still have torsion bars :D
And when I do finally upgrade to a GMT900, it will be a 2500HD. I prefer the torson bars over the coil spring. Seems a heavier set up to me.
I've got a 09 2500HD 4x4 Z71 and the ride is rather stiff. But everything is really beefy underneath if that's what you are looking for. You can't beat a 3,000 lbs.+ hauling capacity :D . But if you can't stand the 4x2 1/2 ton ride, you'll never get used to a 2500HD
There are a lot of differences between the 1500 and 2500HD. The HD has a larger/heavier frame, torsion bar front suspension, heavy duty transfer case, 14 bolt full floater rear axle (10.5" with the gas 6.0 and 11.5" with the Duramax). You also get recirculating ball steering (more heavy duty) as opposed to the rack and pinion setup in the 1500 ( a glorified passenger car setup) . Also the HD has more greasable fittings where the 1500 as a lot of that sealed for life crap on the suspension/steering.
The 6.0 V8 has none of the AFM BS like the 1500 5.3 and 6.0, and you get the 6l90 HD trans as well with the gas motor.
The brake system is a hydroboost setup (uses the power steering pump instead of engine vacuum to power the master cylinder) which is the same kind of setup on many larger commercial type trucks, and provides greater brake line pressure than a vacuum system could ever hope to achieve. And on top of that you get BIG disc brakes all around with 2 piston calipers at each corner.
I went from a 94 f-150 to an 04 2500hd seirra and it rides like a escalade compared to the 94. I also have 3/4 springs front and rear in the 94. Once you go GM 2500HD you'll never go back.
This is all very helpful information guys! I appreciate it. I test drove an 09 2500HD ext cab long bed 6.0 4x4. The ride was much better than I thought, feels very powerful, tranny is MUCH better than the 4l60 on mine. Now if I could only sell the 07...
I also discovered my poor ride quality was being caused mostly by worn out front tires and it needed to be aligned.
I went from a '03 1500ext 4.8 4x4 to a '04 Avalanche and didn't really notice the difference.
When I went from the Avalanche to my current 06 1500HD crew. I definitely noticed the difference.
The 1500Hd is pretty much a 2500. It rides very stiff. I'm used to it now and love it on the highway. I'm not hauling much now and would like a 6 spd, so I checked out a 09 1500 crew 4x4 with the 6 spd. It is a much softer ride. If they raise the GMpoint redemption limits again, I may have to pull the plug.
For the OP, the HDs ride like trucks. JMHO, for a few bucks more, go for the 3500. Hundreds of dollars for more hauling capacity. And the duallys have tons of capacity. just watch those rear fenders.
:thumbs: Ya that's something I've often thought about when I see guys driving these. It must be quite a different experience.
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
    • I have a trailer lights checker I plugged into the 7 way connector in the bed of my truck that has the 5th wheel/gooseneck hitch. It gave the camera side view with the turn signal on just like having a trailer connected but it disabled the rear bumper sensors. I would rather have the rear sensors working.
    • You are winning more than battles. You're winning the war!  Nice.
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
