Roof Racks For Nnbs Sierra?
I kinda like the way the roof racks look on the NNBS Sierra, I just wanted to see what everyone else on the forum thinks. I really have no use for them because I would be scared to scratch up the paint, but I feel that the truck is missing something without them. Does anyone know how they are installed?
Depends if you are looking for a permanent or temporary roof rack.
Myself, I want a temporary roof rack to carry my canoe. Since I have a crew, the canoe over the roof seems the logical place as it will be centered front to back and not stick out. I was planning to use foam blocks and straps designed for that, like I used to do in my younger days with my Civic. It held the canoe solid at speeds over 80mph.
But the truck is high and it's harder to put stuff on the roof, so a roof rack would help protect the roof when loading and unloading. I found this one at a local shop yesterday: Turbo Rack. Looks like crap, but it would only go on seconds before the canoe and would come off seconds after the canoe, so I don't care. Plus it was only 50$.
I really like roof racks on trucks. Around here, most people that have them are simply posers, but I think they're great when you have a use for them. When I upgrade to a crew some day, I Plan on getting the factory rails and buyings some Yakima crossbars to attach to those if the configuration will allow it.
I think it boils down to the fact that it is your truck and you do what you like with it, regardless of what we think!.. Unless it's just a really bad idea!.. :cheers:
I like them....gives you an easy place to attach a wind-deflector when towing larger trailers. ;)
As far as I know you can't get them on the new trucks anymore. I personally like them. I had them added when I ordered my truck just because I liked the look of them and that's the only reason.
  • 6 months later...
I think the roof racks look OK on CCSB trucks... when they're on RC or EC trucks, it makes the cab look too tall/un-proportional to the rest of the truck.
You could always put the "roof rack" over the bed like I did... then it's very functional too (not to mention I think it helps the truck look more proportional).
matt, that looks pretty good. I agree with your statement about roof racks on extended and short cab trucks. Mine will be used rarely it's more for looks, yes I am a poser. It'll get used every now and then though(once every 6 months) I love the look of them on the cab but I don't want to screw one in to my roof incase I ever want it off. Do the yakima's screw in? One other reason I don't want a factory one is because they charge $280 just for installation + $160 for the 2 side rails...what ya think?
I have the Thule rails and they just screw in with special sheet metal nuts that expand with a special tool. You could always take the rails off and cap the new threaded holes with a small screw or silicone....
I believe the factory ones screw in as well..
yeah I know the factory ones do but it's possible to 3m double side tape them. The yakima system comes with clips. I wonder if it just clips on?
No... really, no its not. Have some respect for other peoples safety and don't do that.
No roof rack for me, I like the way the look on the crew cab but I have to many parking garages that are a close call as it is. I already have two that I can't get in and know of two more that I would not clear with a rack.
I won't be able to get in my garage anymore which is fairly important considering we've had tornado's and hail the past 2 days and past 3 weekends. I'm moving into a dorm august 19th though so won't have a garage anymore any who
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
