Rear End Oil?
HvyDty
I have a 1999 GMC K3500 crew cab long bed. What gear oil should I use 75W-90W? My buddy recommended 85W-140W Valvoline high performance. This is my tow rig so I need something for the high temps in the rear... 14bolt rear end. single rear wheel wheels not duel....
Amsoil's website shows Severe Gear 75-140 for the rear. I'd definitely run synthetic
  • 3 weeks later...
Well I use 75/85 synthetic and the manual says to use 75/90. Using a heaveyer weight oil does not make any sense to me. If it was made to use 140 w oil they would have you use it, it is made to use 75/90
What ever you choose...make sure its synthetic.
I use Royal Purple. I have good luck with it.
Amsoil is awesome stuff.
Both of these are very good at decreasing the temp of the diff significantly. I know the RP will reduce it by 20*+. The AMSOIL will even do better.
I would run AMSOIL in everything...but I don't have a dealer where I live.
The AMSOIL site spec's the Severe Gear 75w-140, which means that is what the manufacture recommends, meaning GM so that is what I would run. Remember this is a 3500 vehicle not the average half ton pickup. Which ever oil you choose I would at least make sure it was synthetic. :smash:
