Can You Run Your Parking Lights As Drl?
Sheesh.+ Rewire it to be the way you want it then. WTF can be accomplished by beating it to death here?
Dismount the high horse there, Tex. How hard is it to understand that a how-to for rewiring it was the whole point of this thread? I understand that, how is it that y'all don't? We're not debating legal/illegal or beating anything to death (well, ok, maybe I'm beating to death the fact that several people in this thread are missing the idea of what's being asked for).
dmaxpower that's exactly what I was hoping someone would be able to post. Thanks! :P
Come on man... you can't really think I was serious. Just trying to poke a little fun. I was mainly commenting on how derailed your original question had become because of the illegal versus legal debate...
Carry on!
Sorry if that was the case, just didn't seem that way. :lol::thumbs:
Sometimes it's hard to get the sarcasm working in here. :wtf:
  • Replies 65
Sorry the pictures are not the best I left my DSLR at home and I only have a POS camera at the shop.
I'm just going to give a brief rundown of what to do and the pics are in order to help you figure it out. I don't have time to write a proper how to right now. Perhaps someone who does the mod after me can do better.
This only applies to GMC's. I am pretty sure Chevy's are different but I never looked into it.
First remove the 4 - 13mm bolts holding the drivers side fender brace. It connects the fender to the firewall and is above the fuse panel. (Not shown)
Then remove the fuse panel cover (Not shown)
Next lift up the two handles to release the fuse panel
Completely remove the fuse panel to expose the plugs underneath
Gently release the 4 clips holding the X1 connector in place. The X1 is the grey one in the passenger front corner.
Next flip the harness over and you will see 2 brown wires in position F8 and F5. F8 goes to the left front park lamp and F5 goes to the front right.
Cut the 2 wires.
Strip them and solder in a 6 amp diode to each wire. The band on the diode should be facing away from the fuse panels as shown. This isolates the front park lamps from the rest of the truck so when we supply power to them it doesn't feed back to the rest of the park lights.
Next solder in 2 more 6 amd diodes as shown.
Next cut the Dark Blue wire coming out of B3 of the X1.
Next use I used 3m amalgumating tape and 3m electrical tape to seal up the connections, then twist the 2 remaining diodes together and solder the dark blue wire from B3 (fuse panel side) to 2 diodes.
Next seal up all your connections.
Now put it all back together
And here is the finished result. As you can see only the front park lamps are on when the DRL's are supposed to be on.
Here's a shot with the park lamps on to show you they work normally. You can see the rears are on because I have turned the park lamps on.
And finally all my lights on at once :thumbs:
Thanks for the write up....I just need to figure out if GMC is the same as Chevy wiring wise...I am assuming so.
I'm not going to do it, mainly because I think real DRLs perform a safety function.
I agree that DRLs are a good safety function, but I figure enough other vehicles on the road use their amber markers as DRLs that this isn't compromising that :wtf:
It's all good.
We all (or many of us) drove for many yrs without DRLs and survived. I'm sure you'll be fine. :thumbs:
Couldn't you just remove the fuse for the DRLs and jumper from the power side of that fuse spot through a diode and into the fuse for the marker lamps? This would give you power at your marker lamps when the DRLs should be on. Am I missing a situation where this would be an issue?
In my mind I think of this much the same as how some guys on here made the fogs come on with the high beams or made all the lights come on together. Maybe I'm missing something. I just don't want to have to cut wires if I don't have to.
That would be a lot easier than cutting wires and stuff like the other guy did.
dmaxpower that's exactly what I was hoping someone would be able to post. Thanks! :lol:
Carry on!
Sorry if that was the case, just didn't seem that way. :wtf::thumbs:
You have to remember that you are dealing with a clown! :P A scary one at that!
Carry on!
Sometimes being a smartass in here just comes across as being an ass. It's hard to land those good satirical punches without sounding like you are pissed.
Just figure out how GM did to the Chevy and GMC Express vans. Theyre all setup with parking lights as running lights
That's sometimes the problem with the written word. Many times you need to hear how something is said to get the full meaning. It's a lot easier once you get to know members personalities.
Sometimes being pissed can be an OK thing.
It's all good. :thumbs:
OK, dmaxpower, I have to ask.... where did you get your 6A relays from?
I went in to Radio Shack today and all they had were 3A and smaller, and the auto parts stores I talked to looked at me like I was speaking in tongues when I asked if they had any 6A diodes....
You definitely could do this however your rear park lights would be on as well. I didn't want this. Also you would need to add a relay or find a 10-15 amp diode which I doubt exists.
I was contemplating doing this with the fog lights. I really only did this to help out the OP. I think I still might do it with the fog lights instead. I just wanted to prove my theory more than anything :thumbs:
It's actually a very simple modification to do even going under the fuse panel. All said and done i was easily under an hour including taking the pictures and writing up a quick how to.
Directed electronics.
I am 90% certain you could get away with 3 amp diodes. I'll try to measure the draw of the park lamps and see. Worst case scenario is buy 8 diodes and double up each.
Here are some 6 amp diodes on ebay.
http://shop.ebay.com/?_from=R40&_trksi...-All-Categories
You can also buy heavy duty diodes that are used to isolate the rear tail lights and turn signals when a car is being towed by a motorhome etc. I'll see if I can find them somewhere as they would work perfect for this job.
**Edit. Found what I was looking for.
These would work as well. You would only need 2 of these to do the job of 4 diodes.
http://www.etrailer.com/p-38955.htm
Thanks for the info! I had seen where I could order some 6A ones, but I figured maybe you found a source locally at a store/chain I hadn't been thinking of. I'll just have to order some instead, I suppose. Since I know for sure they work for this job, I'd rather go with something that's already been proven. :thumbs:
  • 7 months later...
I did this mod today and experienced a few things that I want to share.
-When I removed my fuse panel the plugs remained attached to the bottom and required disconnecting to remove
-Don't cut any of the diode lead off. You'll need as much of them as possible to make the connections
-Tape around each pair of diodes before you connect the 2nd diodes together
Other than that it was straight forward using the pictorial in this thread.
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 647 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
