ss502gmc Posted October 24, 2009 Posted October 24, 2009 Today i just noticed on my 01 2500hd that my tow/haul isnt coming on now. Ive never had this happen before and am curious to know if anyone has ever seen this and if so how do i fix it. I dont know the first place to look for something like this. I tried it thinking maybe the bulb burnt but it just doesnt work at all. I fo alot of heavy hauling so id like to fix this asap. Any help would be great!
Hammer2785 Posted October 24, 2009 Posted October 24, 2009 (edited) Have you checked the orange wire in the steering column that runs to the switch. It has a tendency to break and then the switch doesn't work. I fixed mine with a splice connector and some heat shrink tubing. Edited October 24, 2009 by Hammer2785
tjg79 Posted October 24, 2009 Posted October 24, 2009 (edited) Tow/Haul Switch/Indicator Always On or Inoperative 4L60/4L60-E/4L65-E Transmission Circuit Description Tow/haul mode enables the operator to achieve enhanced shift performance when towing or hauling a load. When tow/haul mode is selected, the tow/haul switch input signal to the body control module (BCM) is momentarily toggled to zero volts. This signals the powertrain control module (PCM) to extend the length of time between upshifts and increase transmission line pressure. Cycling the tow/haul switch again disables tow/haul mode and returns the transmission to a normal shift pattern. Diagnostic Aids If the electrical circuit tests are OK and the tow/haul shift pattern is not occurring, there may be a mechanical/hydraulic condition that prevents tow/haul operation. Refer to Symptoms - Automatic Transmission. Test Description The numbers below refer to the step numbers on the diagnostic table. 2. This step tests for a faulty tow/haul switch. 3. This step tests for voltage input from the BCM to the tow/haul switch. 6. This step tests for voltage through the body wiring harness junction block. 7. This step tests for ground integrity at the splice pack. <><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><> 4L80-E/4L85-E Transmission Circuit Description Tow/haul mode enables the operator to achieve enhanced shift performance when towing or hauling load. When tow/haul mode is selected, the tow/haul switch input signal to the body control module (BCM) is momentarily toggled to zero volts. This signals the powertrain control module (PCM) to extend the length of time between upshifts and increase transmission line pressure. Cycling the tow/haul switch again disables tow/haul mode and returns the transmission to a normal shift pattern. Diagnostic Aids If the electrical circuit checks are OK and the tow/haul shift pattern is not occurring, there may be a mechanical/hydraulic condition that prevents tow/haul operation. Refer to Symptoms - Automatic Transmission. Test Description The numbers below refer to the step numbers on the diagnostic table. 2. This step tests for a faulty tow/haul switch. 3. This step tests for voltage input from the BCM to the tow/haul switch. 6. This step tests for voltage through the body wiring harness junction block. 7. This step tests for ground integrity at the splice pack. Edited October 25, 2009 by tjg79 2
Nichevo Posted June 21, 2012 Posted June 21, 2012 This is great. Could anyone please supply relevant part numbers?
Garrett Street Posted June 25, 2012 Posted June 25, 2012 No part numbers needed. There's plenty of wire under the wheel to splice it with a connection. I had to fix mine and it took me about 20 minutes. Real easy and a rare free fix.
tbhuge Posted June 26, 2012 Posted June 26, 2012 Same thing happened to me a few months back. It was the wires coming out of the shifter. If you take the covers off your steering column, it is plain as day which wires we are talking about. Mine was a very obvious break. The wires for this area should have a lot more protection around this area. GM flaw..... If you follow the wires on down it as its own connector. Take the connector apart and one bolt and you can put the entire assembly on your workbench to resolder or fix it. If I were to rate the difficulty of this, I would put it in the beginner category. I had more of a challenge trying to figure out how the covers unsnapped from each other than anything else.
dhoyoss Posted April 4, 2014 Posted April 4, 2014 Tow/Haul not turning on. Pryed steering column covers apart just enough to see the two small white cables wrapped in a orange sleeve cut in half like Hammer2785 said. I also spliced the two wires and wrapped in electrical tape. Tow/Haul now works!!!
Kalabin Posted April 7, 2014 Posted April 7, 2014 I ran into this about two months ago, I spliced the wiring myself but being that it's stranded and like 26awg the splice didn't last. A brand new shifter with the tow/haul mode etc cost a whole 60 bucks. Just removed the old shifter and popped the new on in place. Figure for the cost of an oil change i'll mark it up to maintenance.
ziffel Posted August 28, 2014 Posted August 28, 2014 I thought there were some "gifs" posted with this topic. I don't see them now. I'm having trouble with my 09 tow haul and that info may help. Thanks Ziffel
00Silverado4x4 Posted August 28, 2014 Posted August 28, 2014 (edited) If the steering column wires are the problem; it also could be your brake pedal switch as well. They have been known to give out from time to time. Totally disregard this post, I was thinking cruise control...brake light switch and tow/haul have nothing to do with each other...my apologies. Edited September 2, 2014 by 06SierraZ71 Pulled my head...
ziffel Posted August 30, 2014 Posted August 30, 2014 Not the steering column switch or harness. Check them visibly and with continuity light. Tell me more about the brake pedal switch. Is it part of the stop light switch or a separate device? When I push on the tow haul button the indicator on the cluster is on but it has no effect on the transmission. Loaded or unloaded at any speed. It hasn't worked since I got the truck. The dealer said it is just fine. Quote .."It is operating within the parameters set by GM for that truck that year" I have driven other 09 Silverado's and they work just fine. Mine is a 1500 WT 4.8. Did GM tamper with them in an effort to raise fleet mileage numbers or for some other reason. If so what can be done? I bought this truck to tow an RV so the tow haul is important. Thanks..Ziffel
gmtech4 Posted September 2, 2014 Posted September 2, 2014 (edited) Not the steering column switch or harness. Check them visibly and with continuity light. Tell me more about the brake pedal switch. Is it part of the stop light switch or a separate device? When I push on the tow haul button the indicator on the cluster is on but it has no effect on the transmission. Loaded or unloaded at any speed. It hasn't worked since I got the truck. The dealer said it is just fine. Quote .."It is operating within the parameters set by GM for that truck that year" I have driven other 09 Silverado's and they work just fine. Mine is a 1500 WT 4.8. Did GM tamper with them in an effort to raise fleet mileage numbers or for some other reason. If so what can be done? I bought this truck to tow an RV so the tow haul is important. Thanks..ZiffelDon't start with a conspiracy theory , if the tow haul doesn't work then there is a DTC ,, it may be a pressure change , if some one can get a description and operation for him and post it , that would be great, The reason I ask is I don't have access on my tablet on vaca , I don't want to guess as to the programming change during the tow/haul operation Edited September 2, 2014 by govtech4
ziffel Posted September 2, 2014 Posted September 2, 2014 I don't have a place to get the info. Do you have a suggestion? And what does DTC mean? thanks
gmtech4 Posted September 2, 2014 Posted September 2, 2014 Diagnostic Trouble Code , Someone should supply descrip and operation , it either changes shift points or adjusts transmission oil pressure to hold clutches stronger You can purchase Alldata.com for $27/yr 1
02suburbanZ71 Posted September 3, 2014 Posted September 3, 2014 Diagnostic Trouble Code , Someone should supply descrip and operation , it either changes shift points or adjusts transmission oil pressure to hold clutches stronger You can purchase Alldata.com for $27/yr here we go. tow haul 3.pdf tow haul.pdf tow haul 2.pdf tow haul 3.pdf tow haul.pdf tow haul 2.pdf tow haul 3.pdf tow haul.pdf tow haul 2.pdf tow haul 3.pdf tow haul.pdf tow haul 2.pdf
