Common Problems For Silverados
jro909
just wondering what you guys would say for common problems for the 04 silvys or sierras...the steering clunk is all i know really
Instrument Clusters noisy, malfunction(warranteed to 70K, I believe)
Rear brakes-uneven pad wear, e-brake shoe rubs
Might be a couple other things but in general they're pretty solid trucks
Pretty solid but there are a few things that pop up from time to time.
1. intermediate steering shaft (you already know about)
2. Slip yoke makes noise and can be fixed by re-packing the joke splines with grease.
3. Gauge cluster has been known to give out on the 04's but GM is giving a 70,000 mile warranty on them
4. Either the 4x4 front actuator or the switch on the dash go bad. You'll get a "Service 4wd" indicator on the dash if either one goes.
Otherwise pretty solid trucks.
I have an 03 2WD and I drive it fairly hard..I haven't had any issues...not even the steering clunk. Don't know if its only a 4X4 issue though.
Sorry...I did have the Speedo give out, but it was while I was test driving it...so they got me a new one.
I kinda feel gypped for buying the extended warranty, of course if i didn't it would have been a lemon.
What engine?
4WD switch
radio lights
heater door actuator. The heater door is the biggest freaking pain in the ass. Nothing like blowing 200 degree air on the passenger while the driver gets a refreshing 60 degree arctic chill. A big F you to the jackass the designed the system and the company that makes the overpriced $200 actuator and the $100 labor charge to recalibrate the system.
Since you didn't answer what engine..... if you have the 5.3 then a known head problem exists. Certain Castech heads are prone to cracking and leaking coolant. I haven't heard about a trans pump seal problem. Later models, I have heard about them. Only problems with mine, IP cluster and IS shaft. Both replaced courtesy GM.
Any of the 4L60 trans can give problems if abused.
One source of info would be to gain access to TSB and recall info for your vehicle.
yes sorry 5.3, the whole pump issue is what the dealer told me, alot of trucks go in with the problem
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
