Cold Hard Facts
jro909
just looking for the facts and or opinions i suppose on cold weather start ups and such on trucks, i've read countless articles saying to not let your truck idle and or warm up, because of the oil contamination or carbon build up...let alone fuel waste..i do idle my truck until the rpms idle down to 600 range, because i feel that the rest of the fluids let alone the tranny are cold as hell..but whats the majority around here on thoughts?
Warm it up. But, within reason. Letting it run 30 minutes in most cases would be overkill in my area, IMHO. For the coldest temps we get here, for the first start of the day I might let it go 3 minutes or so max. But, I also take it easy, pretty much let it run at idle speed down the block. Contamination shouldn't be a problem as long as your not short tripping it all the time
i wouldnt worry too much about oil contamination on start up.. the only way that could be possible is if u idled thru many, many tanks of fuel.. u will be fine.. the only thing that would really ever happen that u would see would be when u change ur plugs if u see it all gummed up.. which u wont from just warm up.. put it this way, it has to be done, what would u rather have, a possiblity of carbon build up or blowing gaskets cuz too much pressure or tearing up ur cylinders cuz the oil is too thick to fully lubricate. its gotta be done.
ive read so many similiar topics on other sites asking if warm up is needed and everybody said no modern engines are good to go soon as the motor has oil pressure, but to me watching oil pressure ride 60 to 80 psi seems harmful to the motor, i also read that throwing the truck in gear when the motors idleing higher puts alot of strain onto the tranny....the way i look at it is that i'm already happy with paying at the pump more often then others so whats it matter if i let the truck run a bit before driving
I let mine run maybe a minute, just to get the oil circulating. I live in the northeast where highs temps for the day can remain in the single digits, to below zero at night during January. I don't put my foot into it hard until I've gone a few miles first. Been doing this for 20 years with no ill effects.
Plus, the engine warms up 100x faster rather than idling.
If your temp gets to -0 or below buy a block heater and let it warm up for 10-20 Min's. You should have an idea how long it takes to warm up your truck at certain temps. Just wait long enough until your temp gauge moves or you get some warm air, so your windows don't fog up. I always change my oil in the spring. One last thing, leave your heater fan off and the temp on cold, this will help the motor warm up faster.
I use synthetic fluids....so flow is not a problem...and its rarely below 32* where I live...but even in the summer I let the idle drop off before driving away...I always let the rpm's drop below 1000.
What oil are you running?
mobil one clean high mileage 5-30
I havn't seen Mobil 1 clean... Mobil 1 is synthetic, Mobil clean highmileage is conventional.
MOBIL 1
Mobil 1 Advanced Fuel Economy
Mobil 1 0W-40
Mobil 1 5W-20
Mobil 1 5W-30
Mobil 1 10W-30
Mobil 1 15W-50
Mobil 1 High Mileage 5W-30
Mobil 1 High Mileage 10W-30
Mobil 1 High Mileage 10W-40
Mobil 1 Truck and SUV 5W-30 for Gasoline Engines
Mobil 1 Turbo Diesel Truck 5W-40 for Diesel Engines
Mobil 1 ESP Formula 5W-30
Mobil 1 ESP Formula M 5W-40
Mobil 1 Warranty
Mobil 1 FAQs
NEW BOTTLE LABELS
MOBIL CLEAN 7500
MOBIL CLEAN HIGH MILEAGE
MOBIL CLEAN 5000
Today's electronically controlled engines do not need an extended warm up, unless we are talking crazy low temps. Let it idle for a minute or two and drive slowly for the 1st mile or so is the best method.
Reason I asked about your oil type was your statement about seeing 60-80 psi readings. I'm not seeing those kind of numbers on start up. Mine is about the same hot or cold.
it runs at about 60ish psi at cold start up, if i drive it dead cold it rides that or higher, once it warms and idles down it goes to around 40 psi
btw to the other guy sorry clean is somethen else, its 5-30 high mileage
I run Mobil 1 5-30 (full syn) as well and It's been around -10 or so at night and during startup I'd say mines runs right around 60 PSI at idle. After it warms up it drops to around 40 PSI as well. Seems to be about the same regardless of temp.
BTW - I just hit the remote start when I'm getting ready to go out to the truck in the morning. It usually anywhere form 1 - 5 minutes depending on kid/dog/wife etc. before I make it out there.
A few extra minutes aren't going to hurt anything but your mileage. Plus its warmer when you get in!!
Folks, think of warming up a truck like warming up and stretching before you exercise. YES IT IS IMPORTANT! Cold oil, even Synthetic = thick, which = more pressure when cold which means more work for components. Modern engine or not. Remember, you got your power steering fluid as well that will be cold and thick. If you stick to letting your non-diesels warm up for 2-3 min in temps below freezing, I think that is perfect. Even in 90 degree weather I'll let my truck warm up in the morning for at least a min before driving.
As far as the tranny goes, if you don't care about longevity of the thing, sure go ahead and take off WOT and forget about it. Otherwise, I try to keep the thing below 1800-2000 RPMs for the first mile or two.
I let mine warm up for several minutes at least in the temps we've been having around here (teens). I have no choice. The first minute or so is piston slap. Then if I take off right away, it holds second gear until 30mph, racing the engine (bad when cold) until the trans or engine gets warm enough. Only problem is my last fill up = 11.3 mpg. :thumbs:
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
