A "must" For Every Truck.....
bb123
Do you have one and was it touch to install?
OK, where can I buy one that isn't $900 and above, and where would we mount it? I keep hearing that its too hard to put anywhere without being on top of the darn truck. can be that tough on a nnbs right?
Watch this video:http://www.youtube.com/watch?v=BGYcnYLK_50
This video is of a guy that has too much time/money on his hands, listen at 25sec, lol:
If you go on eBay you can see a few for a decent price. Go on eBay, look up train horn, but listen to the audio. Also, www.hornblasters.com has a bunch of sound bites. The high pitch ones are loud but I like that hearty ground shaking "wake up and drive and put the cell phone down" horn.
I've seen the first link before and it is funny but eventually someone is going to throw a rock or something at their vehicle...the second link is insane... :thumbs:
I have air horns behind my grill and use them only when the time calls for it...like when I see deer crossing the road... :cool:
That guy is a total #*%hole and needs to grow up, he just better hope he doesnt give someone a heartattack from that.
Hey...it's not the guy's fault some person has plaque in their arteries...
True that it is juvenile, but I still want one, not to terrorize peeps but to have for the next snot-rod rice that wants to be funny!
It's cool to have and mess around with to your friends and family, but not people. There are city noise ordinances. Theses guys are going to get theirs ass's kicked one day, because they are going to do it to someone who won't care about going to jail, or have their ride torn up; or worst get shot. If these losers ever pulled that shit on me and I had rock or tire iron, their truck would not go unscathed; then they better hope I don't ever catch up to them or find them....
A buddy of mine has a Nathan 3 chime (thats what they use on most loco's except the new EMD & GE's) on his Duramax. It's the funest thing on earth. Oddly enough he doesn't use it that much but his wife play's with it all the time. I would install one but don't want to pay for the on board compressor.
how are those? Video?
Have you ever seen the two-pack ones at autozone, etc? Is that what you have? Just double? I thought that would be a cheap alternative to a train horn. Imnot trying to spend 4 bills easy on a decent one.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
