Tips for singing "the blues"
General Lee 01
1. Most Blues begin, "Woke up this morning..."
2. "I got a good woman" is a bad way to begin the Blues, unless you stick something nasty in the next line like, "I got a good woman, with the meanest face in town."
3. The Blues is simple. After you get the first line right, repeat it. Then find something that rhymes...sort of:
"Got a good woman with the meanest face in town.
Yes, I got a good woman with the meanest face in town.
Got teeth like Margaret Thatcher, and she weigh 500 pound."
4. Good Blues cars:
a. Chevy
b. Ford
c. Cadillac
d. broken-down truck
5. Bad Blues cars:
a. Lexus
b. Subaru Outback
c. RAV4
d. The Oscar Meyer Weinermobile
6. No car? No problem. Walkin' plays a major part in the Blues lifestyle. So does fixin' to die.
7. Teenagers can't sing the Blues. They ain't fixin' to die yet. Adults sing the Blues. In Blues, "adulthood" means being old enough to get the electric chair if you shoot a man in Memphis.
8. Blues can take place in New York City but not in Hawaii or any place in Canada. Hard times in Minneapolis or Seattle is probably just clinical depression. Chicago, St. Louis, Memphis, and Kansas City are still the best place to have the Blues. You cannot have the Blues in any place that don't get rain.
9. A man with male pattern baldness ain't the Blues. A woman with male pattern baldness is. Breaking your leg while skiing is not the Blues. Breaking your leg 'cause a alligator be chomping on it is.
10. You can't have the Blues in a office or a shopping mall. The lighting is wrong. Go outside to the parking lot or sit by the dumpster.
11. Good places for the Blues:
a. highway
b. jailhouse
c. empty bed
d. bottom of a whiskey glass
Not Blues places:
a. Augusta National
b. Barnes & Noble
c. Red Lobster
d. Dillard's
12. No one will believe it's the Blues if you wear a suit, unless you happen to be an elderly black man, and you slept in it.
13. Do you have the right to sing the Blues? Yes, if:
a. you older than dirt
b. you blind
c. you shot a man in Memphis
d. you can't be satisfied
No, if:
a. you have all your teeth
b. you were once blind but now can see
c. the man in Memphis lived
d. you have a 401K or trust fund
14. Blues is not a matter of color. It's a matter of bad luck. Tiger Woods cannot sing the Blues. Sonny Liston could. Ugly white people also have a leg up on the Blues.
15. If you ask for water and your darlin' give you gasoline, it's the Blues.
Other acceptable Blues drinks are:
a. cheap wine
b. whiskey or bourbon
c. muddy water
d. nasty black coffee
The following are NOT Blues beverages:
a. Perrier
b. Gatorade
c. Zima
d. Slim Fast
16. If death occurs in a cheap motel or a shotgun shack, it's the Blues.
Other good Blues deaths:
a. substance abuse
b. stabbed in the back by a jealous lover
c. cold and alone in a railroad boxcar
d. the 'lectric chair
It's not a Blues death if you die while:
a. playing tennis
b. having liposuction
c. talking on a cell phone during rush hour
d. surfing
17. Some good Blues names for women:
a. Sadie
b Bessie
c. Big Mama
d. Fat River Dumpling
Not so good:
a. Tiffany
b. Calista
c. Tipper
d. Mary Kate or Ashley
18. Some good Blues names for men:
a. Joe
b. Willie
c. Little Willie
d. Big Willie
Not so good:
a. Cameron
b. Trey
c. George W.
d. Carottop
19. Make your own Blues name Starter Kit:
a. name of physical infirmity (Blind, Cripple, Lame, etc.)
b. first name (see above) plus name of fruit (Lemon,Lime,Kiwi,etc.)
c. last name of President (Jefferson, Johnson, Fillmore, etc.)
For example, Blind Lime Jefferson, Jakeleg Lemon Johnson or Cripple Kiwi Fillmore, etc. (Well, maybe not "Kiwi")
20. If you own a computer, you cannot sing the blues, no matter how many men you shoot in Memphis.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
