Bull Bar
i have seen all kinds of differnet bull bars out there and i have a specific question about them that i didn't find any answer to after many hours or searching and reading which i do all the time.
My question is, what brand name makes the bull bar that does not block the chevrolet emblem out front. I have seen many different pics and some bull bars are higher and some are lower, almost through the lower valence instead of tow hooks. has anybody experienced this with pics? i am trying to make a decision to get one or not, i do not want any bar to look "odd" and cover the emblem it just doesn't look right. I want it to flow with the front of the truck. Any info would help here thank you.
I own a blue granite metallic gmt-900 chev silverado.
Does anybody think it would look good black line-ex'd on the front>? suggestions
Id say Westin or Uu Guard like the one in my sig...make sure you get stainless steel one not one of the chrome plated ones...
Here is a westin one ... http://www.gm-trucks.com/forums/index.php?...st&id=13982
I really like the bull bar in the linked pic. You don't happen to have a part number do you?
Here is the list of part numbers it depends on what size tube you want and if you want black or stainless... http://www.accessconnect.com/Westin_Bull_Bar.htm and the bull bar in the pic is part number 32-2270
I had a feeling it was westin and i searched their website and looked at the installation instructions for the "ultimate" and it stated you have to remove tow hooks and NOT replace them. The pic that you attached is awesome thats the one i want but the instructions don't match up. this is why i asked i am still a little confused. Are people modifying to lower the bar?
Im not too sure id assume that they could be modified but most of them involve to hook removal... I had installed a westing a couple of weeks back for a friend on his 2009 and his tow hooks also needed to be removed and u can have the bar higher or lower depending on how you mount the bar to the bracket... Sorry thats all i can say maybe someone else will chime in.
so there was an adjustment for a higher or lower install? did his tow hooks get put back on?
Yes there was and adjustment but it was like only a 2 inch difference and the tow hooks were not put back on..
ok cool i just want to mount it as low as possible, thanks a lot for your help.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
