Got Rearended. 2007 Nbs Sierra. Bumper?
I recently got rearended and was wondering where would be the best place to buy a replacement bumper if I need one. The bumper itself looks fine, but it just bent down. I dont know if there are some brackets that got bent or what. I have a hitch on the truck and it took all the impact, but wasnt sure if I will need to replace the whole bumper. Thanks in advance.
I got rear-ended about 5 months after I bought my truck. It ended up costing about $700 to fix the 'bumper'. It was a light bump and the only damage was to the bumper. The van that hit me didn't have any visible damage either. They replaced something like 3 or 4 pieces of the bumper as it is something like 7 pieces all together.
I would consult a body shop before you do anything else -- they'll be able to evaluate the damage and give you a pretty good idea what will need to be done when they quote it out for you. From there you can decide if you want to tackle it yourself or not.
The "bumpers" on these trucks are not strong at all. I backed into a trailer once and I was probably only going about 1MPH and it left a good size dent in the left side. The dealer wanted over $350 just for the one chrome section. I said the hell with that and found one at a swap meet for $50 but it is very time consuming replacing it since it is rivited on.
well hell there goes my idea of trying to find a painted denali bumper at a junkyard to swap out, I hate messing with rivets.
Yeah I am gonna see. The bumper itslef I dont even know if it was touched. The hitch took the impact. Anyone know what they will have to do about the backup sensors?
Maybe recalibrate them or something if they weren't visibly broken? I'd actually make them replace the sensors if they don't have some sort of recalibration for them to do. The last thing you want is to have your backup sensors go all hay wired a few months down the road.
Are they not footing the bill for the collision? Or do you not want to turn it in and have it on the trucks track record? Otherwise if they are handling the bill I would say just have a body shop fix you up on the person's dime. I think you would be happy with the result and you wouldnt have to do anything but retrieve estimates for the work. With that said if you want to tackle it yourself, ebay, craigslist, local bone yard, ect. would prob have the replacement parts you are looking for. You could also go to the dealership but it will cost you some crazy $$$.
If I had a GMT 900 this is what I would do...... Tough Country makes some NICE STUFF.. Deluxe Rear Bumper. If they do much more weight reduction of these trucks we are going to drive paper cans.
Jbo
Gotta remember folks, today's trucks are built to crumple, (Crumple Zone) as per mandated safety standards and crap like that. That's why the bumpers don't take alot of abuse. That and lighter weight = better MPG.
Granted.... but there's something to be said for putting "My big-ass truck: 1. Your little tin-can econo-box: 0." on the scoreboard.
Now, it's both sides of that collision posting a 0 score. :thumbs:
Very true, bumpers today are mostly for looks anymore and they are not the bumpers of the 70s.
I am not even sure if you can call them bumpers. I think that "rear end finishers" would be more appropriate. These things are not meant to be bumped.
You should see the rear bumper on my old '84 Mercedes 500SEL car. The bumper itself has a thick painted plastic cover, but underneath is a heavy steel reinforcement bar, there is a very thick (5/16 inch thick at least and 4 inches wide) chromed steel filler bar on top, and of course there are twin shock absorbers that transfer the shock into the underbody of the car. There would be no damage visible at all if you backed into something at 5 MPH, provided it is nothing sharp. Yes, the old 126 Mercedes chassis, built like a tank. Sadly, nobody builds cars or trucks like this anymore, not even Mercedes. It is simply not economically feasible given the stiff competition.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 885 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
