Hey I got the clicking to stop here is what i did. took off the heat shield and located a crack in the exhaust manifold. then I used a product QuickSteel for high temperature can pick it up at any auto parts store I then mixed it up till it looked like toothpaste. then I let it stand for about four and a half hours before testing I went around the block and the noise was gone. I would let it stand for 24 hours though if I were you before you test it when I tested mine it made a giant bubble. Fortunately it held and I just pushed it back in place.I'm not sure how long it will hold up but for 10 busks and 10 minutes of work time its worth a shot verse 150 bucks and between 1-3 hours of work time. At least we know what the sound is and can fix it now.
  • 5 years later...
On 11/7/2014 at 12:42 PM, dbroman3 said:
Can anyone confirm that they have the same noise that is in Z06killers video ? also found at this link
It is exactly what I have. Almost sounds driveline related, possible axle or front drive shaft being that it is AWD. It does NOT make the sound during rev only under driving acceleration.
I do hate the sound but more interested in making sure it isnt something major that can go out on me while driving.
Yes, I have the exact same problem and noise that just started last week.
  • 2 years later...
Starter kick out spring is weak or washer that holds the kick out fork is coming loose/off the grove inside the starter, let's it touch the flywheel at times. Also from what others have said possibly crack in the manifold..
