New Member From Sc
mossicle
Hey All,
Ive been reading the GM-Trucks.com threads as a guest for a couple months now and i finally decided to take the plunge. I also recently decided to get back to my roots and get my first full size pickup. Took delivery of a 2010 Silverado 1500 with the 5.3 and Z71 package this morning! Ive had trucks in the past but for the past few years i switched over to a VW. so far (only 22 miles on it) im completely happy with the new toy!
Welcome and btw...
Thanks... By the time i got back from the dealer it was already too dark for pics but ill try to add some tomorrow, if i can figure out that process.....
Welcome ,and i guess your off driving your new toy!!!
Where in SC me too and I just bought a new 09 GMC sierra 2500 reg cab 4x4.
Thanks Drew. im upstate near Lake Robinson. lots of nice mountains, lakes and state parks to play in up here!
Welcome and btw...
Finally got a chance to take some pictures of the truck.
Went with Taupe Gray Metallic which i was told is a new color for 2010.
Im hoping to add a spray-in bed liner as the first mod, just haven't decided which brand yet, Line-X or Rhino
http://carphotos.cardomain.com/ride_images...60001_large.jpg
http://carphotos.cardomain.com/ride_images...60003_large.jpg
http://carphotos.cardomain.com/ride_images...60002_large.jpg
http://carphotos.cardomain.com/ride_images...60004_large.jpg
http://carphotos.cardomain.com/ride_images...60005_large.jpg
http://carphotos.cardomain.com/ride_images...60006_large.jpg
http://carphotos.cardomain.com/ride_images...60007_large.jpg
Welcome and btw...
Love the upstate and the mountains my two signature pictures were taken in Asheville NC.
Where are you SC guys located?
Mark:Jesse is up near greer and I'm just west of you in Hopkins near McEntire AFB.
I quoted the wrong post but anyway I used to spend a lot of time up there near by in and around Asheville and Hendersonville,I need to get back up again soon!!!
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
