Blackbear Tune
I bought my New Truck back in November of 09....since taking delievery of the truck, I noticed right away how great the Blackbear Tunes really are for these trucks.....turns out I had traded my Blackbear Tuned 07 for a Stock 09, and pretty much regreted my decision from the 100 miles I put on the new truck....well anyway I got ahold of Justin and ordered a Tune for my 09 and once the weather broke, I took the time to put it in, and had the Vette Servo Installed. I can honestly say, I really like the 09 Truck now! So anyway to Justin and Jenna at Blackbear Peformance, I can't Thank You enough, you have made my 09 Sierra a fun to drive truck. For everyone else sitting on the fence about what kind of Tune to get, I hope I answered your question!
I get my Black Bear Tune this coming Friday at 4:30. It's like Christmas time again :P
I installed the spare modules yesterday and did the security re-learn. The first 5 or 6 miles driving after that, the truck felt really sluggish, but cleared up eventually. It seems OK now, except for the crank re-learn that is needed.
I installed a Magnaflow Cat-Back system (single side exit) and a Volant CAI during the last 2 weeks, so I think I am about done with things for now.
I am still thinking I would like to have 3.73 gears instead of the 3.42 though, but it isn't a big enough jump to make the switch, and I do too much highway driving for a 4.10 gear IMO.
Hey fellas, sorry to interject here, but I was looking for instructions on how to swap my tuned ECM/TCM with the factory ones I kept. I know how to physically swap them, but I forgot about some other stuff. I.e. do I need to disconnect my battery? Do I need to keep the key in the on position? Any other quirky stuff I should worry about or can i just shut the truck off and swap 'em?
Oh, and by the way, love my tune. Had it since Dec '08 and would do it over again.
I am considering a tune but I am nervous about my warranty being voided since the truck is so new and the warranty goes to 100k. How big a deal is it to install a stock ECM for warranty work? Will the dealership be able to detect the tune in other ways?
Responded to your PM. But for everyone else, swapping back to stock is just as easy as swapping your tuned modules in. Same procedure, just make sure your key is not in the ignition.
Some folks will unplug the battery for added safety.
The few times I've swapped my computers I disconnected the negative battery cable just in case.
I too am getting tuned Saturday, can't wait. Installed Corvette servo Sunday, very noticable difference. I have not installed ECM/TCM yet maybe Thurday or Friday. This forum has been one of the best finds on the internet for me. The integrity of this forum seems to be second to none.
Thanks gm-trucks.com!
It offers a more robust 1-2 shift servo, folks should see crisper snappier shifts due to the increased surface area of the servo.
I also traded an 07 tuned truck for my 09. But I knew I d tune that truck too. Did you think the 09 wouldn t need the tune too? :P
Nah....I knew the 09 would need tuned too....I think its just that the 09 was lacking something from the start, and winter has been long this year so I haven't really got to enjoy my new truck yet....I swear I'll never buy another new truck in the winter again....I like to keep em clean and mod them out....there's no doing that in the winter around here!
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
