Just Installed My Cb
KMGZ400
i just finally got around to installing my CB.. i was having trouble on where to put it since i have a center console.. my old truck didnt have center console so i just had it mounted right below the radio and it was perfect... i have had the CB in this spot for a few weeks now and it is a perfect spot.. i dosent get in the way at all.. i snapped some pics of my truck too!
its just a basic cobra CB and a firestick antenna... does anyone have any tips or tricks on how to make the range better?
lots of pics
i just have to ask why? in a world full of cell phones cb is dead technology
Depends on why you have it.
If you off-road with a club, communicating from vehicle to vehicle is easier with a CB than with a cell-phone.
When we travel with friends, I have an extra CB I temporarily place in their vehicle. On our last road trip (approximately 5000km trip), a lot cheaper than using cell phones to communicate.
And those small FRS radios are useless.
Good for talking to opposite traffic ( 18 wheelers) on road trips. They will let you know what the road ahead has in store (cops,traffic). By the way nice install but like hockeypro1411 make sure its tuned, buy you a meter and check.
yeah i got it tuned... i use it because all of my freinds have them and its good for offroading and just driving around talking... i also enjoy talking to truckers and listening to what they say.. it keeps me awake on long trips.. IMO its a good investment
ah i gotcha, wasent knocking it...the majority of truckers i deal with use cells with dushetooths..just curious
haha you mean bluetooth? if so i agree that it is extremely gay.. people think they are so cool walking around screaming into an earpiece.. meanwhile they look like jackasses
Something funny about 1960s hillbilly technology (CB) next to an ipod!!
I have a CB in my truck, with an antenna NMO permanent mount on the roof. I usually have the cap on, but when I'm going on a trip I screw the antenna on to listen to the truckers.
CB's are fun to mess with, and if you have a nice setup.... you can even shoot skip to other countries, or just other states. I used to run a Cobra 29LTD Classic w/ an 800W linear on it, and a Merlin Double Coil.... that was setup for a std cab truck specifically.... I have a whole closet full of old CB's just cuz.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
