T-case Leak On 08 Crew
Well guys t-case is leaking out of the tail end after 6 in lift. Anyone had this issue after lifting there truck? Info would be great thanks
not that i have heard.. mine didnt do it.
I checked the level and its just a tad bit low. I noticed oil above the t-case where it slung it under the body. just a light film between the frame. I just wundered if anyone noticed it.
I know when i did my lift you needed to cut into the Transfer case for it to sit in the subframe not sure if this was nessisary with the lift you did... is it possible whoever did it actually went too far and cut into the t case itself and not just on the heat shields that you are supposed to cut
i would go look but its raining
You had to cut into the Transfer Case, or the Front Differential housing???
The OP is discussing the Transfer Case, the part behind the transmission... not the Front Diff (which needs to be trimmed down on many lift kits to fit correctly in the new subframe)...
Sounds like maybe the rear seal is leaking where the slip yoke is...happened the first time I removed my rear driveshaft on my old '83 K5.
  • 1 month later...
