Evolution Of My Gm Trucks!
Thought I would start a fun thread which everyone can post pictures and give a little back ground on the evolution of their trucks. From bone stock to current status. Ill start
First GM Truck:
2005 Colorado Z71 4x4...
Which later became this when I wanted something bigger:
2005 Silverado Z71
Then later became this when I test drove a new Sierra:
2009 Sierra Z71 4X4
which at the time was bone stock and little by little molded it to this:
The End
Hmmm.. it seems as time goes on, you're member is strinking and you need to compensate. :)
Just kidding, new ride looks sweet. :noway:
Ha! ... I am one of those who have that car-itus where I have to get a new vehicle every so often. Get bored quick, but seeing that era of mine was back in my single days and now I am married with two kids. Those days are long and gone so sticking with the Sierra till it falls apart. Thanks though.
Most likely Govt. Storage seeing, I should be getting PCS orders sometime late this year or next and my choices for where I want to go is the Pacific where I wont take any of my vehicles due to the salt water. Plan on staying overseas for the rest of my career which means my truck will be paid off by the time I get back stateside seeing I cant ship it due to TMO regulations on vehicle heights and weights. Probably pick up a temp car at whatever assignment my career takes me. Being a military brat myself i've seen first hand how these shipping companies who ship your car treat them and damage caused.
I can relate to this man. Everyone of my vehicles has gotten progressively bigger. :cool:
Nice trucks bro, which is your favorite truck?
The Sierra...
I went from
1995 S-10 Extended Cab 4x4
1999 Silverado Ext Cab 2WD Work Truck 4.8L V8
2004 Colorado Extended Cab Z71 4x4
2006 Colorado Crew Cab 2WD
2006 Silverado Crew Cab 4x4
All trucks were absolutely awesome and did everything I wanted of them. Only major trouble was battery issues with the S-10 Caused by my stereo. '99 Silverado was a victim of road rage but was repaired, 2004 was given to my dad to trade in on a tow rig, 2006 I just got bored of and wanted a V8 again and also 4x4, the current '06 Silverado is everything I have wanted in a truck.
First new truck was a 1975 GMC RC 4x4,350V8, Full Time 4WD. This truck was underpowered, around 165HP I believe and thirsty. 35yrs and somewhere around 30 trucks later to My current Silverado.
What did you do with your All Terrain wheels?
First GM Truck:
2005 Silverado Z71
2009 Sierra Z71 4X4
The End
My very first car was a truck...a 1975 Ford Courier 4-cylinder, which I purchased for $750.
I then went through 2 cars and came back to the truck scene with a 1999 Silverado K1500 5.8L 4x4. Here it was stock:
...and after a little mod'ing:
Then I upgraded to my newest baby. Here she is stock:
...and after some upgrades (The Z71 stickers are coming off once the weather warms up):
I got rid of them as quick as I could. Quick cash in the pockets seeing those wheels are a hot item around here.
Don't u mean 5.3l?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
