Quite A Surprise When I Got Home Last Night...
dsr611
Background info: I found a set of Raptor Series 5" oval steps on Ebay a little cheaper than other places I looked. I bought them using the Buy It Now feature and submitted payment via PayPal. A few hours later, I get a phone call from the seller saying that the steps were out of stock and they gave me the option of waiting on the steps to come in or I could cancel the order. I canceled the order and found the same steps somewhere else. The money that I had paid via PayPal was refunded to my PayPal account and I transferred it back to my bank account. I ordered the steps from the 2nd vendor and got email confirmation that they had shipped. They arrived at my house yesterday. When I got home from work, there were 2 boxes sitting on my deck. I thought that, maybe, there was one step in each box. Opened the 1st box and it was a complete set (2 steps and mounting hardware). Opened the 2nd box and it too was a complete set. Find the packing list for both boxes and one set was from the 2nd vendor. The other set was from the Ebay seller. Undoubtedly, they went ahead and ordered the steps from the manufacturer and later called me to let me know they were on backorder and offered to cancel the order (which I did). So, now I have two sets of steps and only paid for one set.
I have emailed the 1st seller and explained to them in detail the circumstances and offered to ship the steps back to them (on their dime of course). I also asked that they contact me by phone 1st thing tomorrow to clear this up by speaking to someone instead of just through email. I could have easily said "Forget it, they made a mistake and shipped them to me after they refunded my money", but I'd hate to think that someone could possibly lose their job over a mistake like this. Plus, I know that if I would not have tried to do the right thing, karma would have come back and bit me on the butt!!!!
It's nice to know there are still good, honest people out there. Good job man. :)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
