Exhaust Leak Gmt 900
Have any of you guys with GMT900's with the 5.3 experienced an exhaust leak sound? The reason I ask is that my 09 which has 9K on it now, has done it since about 1K miles....it is a slight ticking which seems to be coming from either the exhaust manifold, or maybe even what I call the exhaust donut between the Exhaust Manifold and the Y-Pipe...it is audiable under a light load and ticking which seems to be underneath my feet....wanted to get your guys input, or see if there was any TSB's out there on this.
Mine does it. Sometimes when I start the truck it's pretty loud but gets better after a few seconds when the manifolds get hot. It has to be the manifolds or the y-pipes. I installed a cat-back and it didn't fix it.
installed a cat back system on mine the other day.....the joint behind the cat seems kind of "micky mouse"...if i had to guess i'd say its leaking around that clamp.
That's where mine leaks. And if you've installed an aftermarket cat-back, that clamp may warp the muffler pipe if you tighten it too much without checking the fit as you tighten the clamp.
