First Pickup And A Question
Hello all!
Recently picked up my first pickup ever: a shiny red 2010 Silverado 1500 LT extended cab 4x4 w/ the Z71 package, and the Power Pack Plus (5.3L, locking diff, etc).
So far, so good... I'm getting my bed liner installed this weekend, along with the heated seat kit.
Quick question: what is the weight rating on the built in hitch platform that comes with the trailering package?
Hopefully this goes better than the last GM product I picked up a few years back (a 1988 V20 Chevy Suburban that threw a rod and left me on the side of the freeway at 11:30 at night). :thumbs:
Hello all!
Hopefully this goes better than the last GM product I picked up a few years back (a 1988 V20 Chevy Suburban that threw a rod and left me on the side of the freeway at 11:30 at night). :rollin:
I think GM quality on new vehicles has been greatly improved over the 80's models. However, there is always chance that something bad can happen to your new truck. The probability is less though. And warranties are much better too.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
