2.5 Spacer Lift - Won't Work On 2010 4x4 Tahoe?
Installing a 2.5 spacer lift on the front of a 2010 4x4 without success. I'm using the spacers which mount on the top of the struts. Got it all apart and while putting struts back on I ran into a problem.
The lower shock mount is angled in the bushing. When you rotate the strut 180 degrees to reinstall the lower mount angle is reversed in the wrong direction. This results in the strut angling SIGNIFICANTLY outward away from the top mount. You can put a GREAT DEAL of pressure to push the strut back in towards the top mount. However, the force required winds the lower mount rubber bushing up like a spring. If I were to lose my grip it would snap back with such force that it could cause significant injury. No way could it be good for the components putting this much "spring" tension of the lower bushing.
Left and right strut are identical. Switching sides doesn't work. I ended up putting it all back together in the stock arrangement. Waste of time.
Any thoughts?!?!?!
Rick
1. did u contact the manufacturer of ur leveling kit?
2. is your vehicle listed in the applications for that part number?
3. what kit did you use?
I bought the kit off eBay quite a while ago and listing is no longer available. I'm quite sure the listing provided for my year. It's the round aluminum spacer which you botl to the top of strut and rotatoe 180 degrees and reinstall using new bolts supplied with the spacer.
last one i did i swapped the struts side to side, bolted right up no issues. shouldve gotten the rough country lower spacer anyways, can be installed wtihout pulling the strut out of the vehicle
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
