Echofox Posted June 16, 2010 Posted June 16, 2010 So I recently had my Procomp leveling kit installed. The truck looks GREAT! However the ride has stiffened up dramatically. I knew it was gonna stiffen up a bit but some of the knocks she takes are really really rough to the point it makes me cringe. Just wondering if there is anything I can do to help this. The truck has about 70,000 miles on her now and has never had the shocks done. Would a set of Bilsteins for 0-3" help this at all? Also on the highway if I stomp on it, once she drops I get a fair bit of vibration that wasn't there before. Not sure if it's wheel hop or what. Any suggestions on what I can do to bring my truck closer back to stock ride other then removing the keys?
oldschool327 Posted June 16, 2010 Posted June 16, 2010 If your Shocks are 70K old then they definetly need swapped
Matt_ Posted June 16, 2010 Posted June 16, 2010 shocks may help some.. or they may firm up the ride even more. the rough ride it primarily due to lack of down travel. check and make sure your upper control arms arent touching the metal droop stops... if they are then you have 0 down travel and need to decrank a bit. dont expect any miracles... cranking the bars makes the truck ride like crap. been there/done that.
dirtfan21 Posted June 16, 2010 Posted June 16, 2010 shocks may help some.. or they may firm up the ride even more. the rough ride it primarily due to lack of down travel. check and make sure your upper control arms arent touching the metal droop stops... if they are then you have 0 down travel and need to decrank a bit. dont expect any miracles... cranking the bars makes the truck ride like crap. been there/done that. I can second that FOR SURE! My 2000 had them cranked with the 3" BL to fit 33x12.5 Mud Terrain BF's. That thing rode like the John Deer tractors I drive for my grandpa on the farm.
J-man67 Posted June 16, 2010 Posted June 16, 2010 Yeah, they may be cranked too much. Especially with re-indexed keys, which I'm sure are included in that kit. Did you do anything to the rear?
Echofox Posted June 17, 2010 Author Posted June 17, 2010 No never touched the rear. Just cranked up the front enough to get rid of the front end sag and make the truck level. Matt - Beautiful truck you got there. You say been there, done that. What are my options to get back to a stock ride or better? Last vehicle I lifted was a TJ with a Skyjacker lift and that thing rode like shit after that. I'm not opposed to lifting my truck but if I'm chucking a couple grand I want a good ride there after.
dirtfan21 Posted June 17, 2010 Posted June 17, 2010 I know this is way out of the ballpark in the height you are probably looking for but, I want to share it with you. I drove my uncle's 2004 HD silvy, with a 7" BDS and keys on the front to clear 37's. That thing rode awesome, I mean awesome. Could it be the keys are doing this? I have rode in trucks with keys and they ride good. I thought the main reason for adding keys is to keep close to the factory crank on the bars.
Echofox Posted June 17, 2010 Author Posted June 17, 2010 I'm not opposed to a 6" lift. That's probably as high as I'd like to go but like I said I'm more interested in a comfortable ride.
Matt_ Posted June 18, 2010 Posted June 18, 2010 No never touched the rear. Just cranked up the front enough to get rid of the front end sag and make the truck level. Matt - Beautiful truck you got there. You say been there, done that. What are my options to get back to a stock ride or better? Last vehicle I lifted was a TJ with a Skyjacker lift and that thing rode like shit after that. I'm not opposed to lifting my truck but if I'm chucking a couple grand I want a good ride there after. Either a true 4 or 6" suspension lift OR a 3" body lift. You will not have a stock ride by cranking any torsion keys, be it stock or aftermarket.
hockeypro1411 Posted June 18, 2010 Posted June 18, 2010 I'm not opposed to a 6" lift. That's probably as high as I'd like to go but like I said I'm more interested in a comfortable ride. Doooo iiiit!
Wingnut Posted June 18, 2010 Posted June 18, 2010 No never touched the rear. Just cranked up the front enough to get rid of the front end sag and make the truck level. Matt - Beautiful truck you got there. You say been there, done that. What are my options to get back to a stock ride or better? Last vehicle I lifted was a TJ with a Skyjacker lift and that thing rode like shit after that. I'm not opposed to lifting my truck but if I'm chucking a couple grand I want a good ride there after. Either a true 4 or 6" suspension lift OR a 3" body lift. You will not have a stock ride by cranking any torsion keys, be it stock or aftermarket. As you said before though...Longer shocks make a HUGE difference. I did this on my '02 after I cranked the bars...Downtravel is what was shaking the fillings out of my teeth. So I bought the cheapo Procomp shocks for a 0-3" lift, put them on, and it was then just a hair rougher than stock.
Matt_ Posted June 18, 2010 Posted June 18, 2010 No never touched the rear. Just cranked up the front enough to get rid of the front end sag and make the truck level. Matt - Beautiful truck you got there. You say been there, done that. What are my options to get back to a stock ride or better? Last vehicle I lifted was a TJ with a Skyjacker lift and that thing rode like shit after that. I'm not opposed to lifting my truck but if I'm chucking a couple grand I want a good ride there after. Either a true 4 or 6" suspension lift OR a 3" body lift. You will not have a stock ride by cranking any torsion keys, be it stock or aftermarket. As you said before though...Longer shocks make a HUGE difference. I did this on my '02 after I cranked the bars...Downtravel is what was shaking the fillings out of my teeth. So I bought the cheapo Procomp shocks for a 0-3" lift, put them on, and it was then just a hair rougher than stock. It varies. I tried a few different variations of shocks on my 2005 with the bars cranked 1.75" and the thing still rode like a tank. Softer/Harder/Longer/etc shocks didn't make a difference. It still rode like crap. Maybe it's because I was a mechanic so I rode in other stock trucks daily... so i was reminded every day how much stiffer my truck was then a non-cranked one. I got tired of it after a few months and bought the 5-6" Superlift FIT kit... BEST decision i ever made with that truck. After that, it rode like a dream
sonjaab Posted June 19, 2010 Posted June 19, 2010 Just wait till you have to replace your balljoints next year ! You will be really LOVIN' that leveling kit then...........
jro909 Posted June 19, 2010 Posted June 19, 2010 Just wait till you have to replace your balljoints next year !You will be really LOVIN' that leveling kit then........... +1 my next truck will have a lift kit built into it...3500HD
