Can Some of you Super-modders post up links to the best mods here in just a summary format the puts it all in one place. This way it could potentially be pinned and make a real good reference.
Thanks
I'll start:
Steering Wheel Radio Controls Add On:
http://www.gm-trucks.com/forums/index.php?showtopic=69369
http://www.gm-trucks.com/forums/index.php?showtopic=69054
http://www.gm-trucks.com/forums/index.php?...100236&st=0 (make your own harness)
Complete Wheel Part Numbers
15917933 is the steering wheel with TITANIUM inserts
15917931 is the wheel with the BLACK inserts
Add-a-DIC-tome
http://www.gm-trucks.com/forums/index.php?showtopic=63291
http://www.gm-trucks.com/forums/index.php?showtopic=113704
Full Panel - 19159438
Switch only - 15947841
Adding a Cargo Light switch
http://www.gm-trucks.com/forums/index.php?showtopic=107730
Adding a Center Console - Part Numbers
http://www.gm-trucks.com/forums/index.php?...st&p=634172
Edited by splat10
Not on this site but good writeup:
How to remove/replace GMC GMT900 grill
http://www.truckmodcentral.com/forums/showthread.php?t=1091
http://www.truckmodcentral.com/forums/show...t=billet+grille
GMT900 Projector Headlight Writeup
http://www.gm-trucks.com/forums/index.php?...mp;hl=headlight
Bed Underrail Lighting
http://www.gm-trucks.com/forums/index.php?showtopic=93508
Custom Sheet Metal Gap Guards
http://www.gm-trucks.com/forums/index.php?...=81181&st=0
Install/Change door handles
http://www.gmfullsize.com/forum/showthread.php?t=93769
Edited by LSU_Dark_Knight
There should be one post that has all the links in it for easy reference
Even this thread could work if the original post gets updated.
What I'd like to see is a clear cut post about adding factory foglights to a Sierra including part numbers and perhaps even wiring instructions.
This would be right up there with the "add a DIC" mod
once we get a good list then we can cut and paste them all into one post and ask the mods to pin it. Post #3 is all about fog lights. I haven't read it because i have fog lights on my z71 but it lookes like the info needed is right here.
Well it's been pinned so go ahead and start updating your original post.
As far as adding fog lights to the Sierra, that write up above is for Silverado's as far as I know. Installation on the Sierra's should be really easy and wiring should be the same as the Silverado's wiring.
Yes, wiring should be the same.
Part numbers would be perfect.
If I tackle this project before this thread gets updated; I'll post the info myself but i'm hoping someone that has done this already could update.
    DWic
    DWic
  • Who's Online   4 Members, 0 Anonymous, 714 Guests (See full list)
