General Grabber At2's Vs. Cooper Zeon Ltz's ( In Snow )
MikeSgmc
It's between these 2 tires for some factory 20's. I do lots of highway driving, some light towing, but mostly paved country roads with hills to give you an idea. Living in New Hampshire, winter conditions are pretty wild. The bottom line is, I am used to driving a Silverado SS with Blizzaks in the winter (unstoppable.) With the NBS truck, I am only running 1 set of wheels and tires for the whole season. I need the tire with the best snow traction. Any experiences with either in snow/ice ??? Which tire is softer? Thanks.
Both are awesome tires,... it's really up to what ever price is the best in my mind. I'm currently running the Cooper Zeons and love them. They did awesome this winter and we had alot of snow. The General AT2's are a poor mans BFG kO's. I say that with love. They are just cheaper than the bfg's with almost identical specs and tread. They also come with a warranty unlike the BFG's. I'd even say they both weight in about the same too (AT2's vs. LTZ's).
You can't go wrong with either set in my opinion.
:thumbs:
I've had the coopers and they are awesome tires.
My next set im going to give the AT2's a try.
FWIW... i think the AT2's are a better looking tire than the BFG. The tread pattern of the ATKO's seem closer together and C-shaped whereas the AT2 has more of a mud-terrain tread shape, but spaced closer than a MT. If anything, I'd say that the AT2 looks more like the Pro-Comp AT than the BFG...
FYI: i posted those pictures in the order that I would buy those tires...
Yea the AT2's look great. Just trying to get the best snow performance possible for an all terrain tire. The BFG's are way too popular, I see them on so many trucks around my area, no way am I paying for them either.
I currently runthe zeon ltz's and they are a great all around tire and also performed awesome in the record snow we had here in Northern VA last winter. I drove through one of our deepest snowfalls(about 18" I think) with no problem. I've had Bridgestone duelers, BFG A/T, Yoko geolandar, and many more A/T tires and these imo are by far the best. And than anything else, they don't cost an arm and a leg like the BFG or Bridgestone tires.
+1 on the Generals,...coming from your next door. 2wd in light to moderate snow,...awesome tire. Best seller at my local "Tire Wharehouse"
The Generals are really good in the snow. I had a set on my 2wd Ford Ranger and I was one of two people that made it to work when we had a nasty blizzard in Nebraska.
i wanna see pics when ya get them on so i can see how that size looks :cool: where did u get them?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
