Zone 3.5" Lift Came In Today!
Im pretty excited to get this on and going but as soon as it came in I called a local off-road shop and asked how much they would charge to install it and he said it would be around $700 total! :thumbs: I didnt expect someone to tell me I would be close to tripling the price of purchasing to install so I told him Ill look around some more and call him back, which I wont, but I was just wondering how much did it cost yall to install this if you have it? Also, how much should I be looking to pay for it?? Thanks yall
Most shops, at least in my area, charge around $500 to install a body lift and around $200 for a leveling kit. You may find a better price but I wouldn't count it being less than $500-$600. If you don't want to install the kit yourself, then you are stuck paying a shop. But most front end shops will install a leveling kit and align for around $100, so you could save some money right there. Good luck and happy hunting.
Damn, that's more then the average install price for a full lift kit. Hence the reason I installed mine myself. I would give that a try before paying that price!
Don't have any buddies that are mechanics? That's always the best way to go. I'm letting my friend put my body lift on for about 200 bucks.
Around here they charge 350 for the 3" body lift since you've got the 1.5" bl there is no way you should pay 500.
I would try BlackOut's advice on the front end shop putting on the level since they can align also. But find someone else to put that BL on. I paid 120.00 to have my 1.5 put on my truck. Now it was under the table kind of deal the shop let me pay one of their workers cash to put it on and the shop didn't get any money but the manager did me a favor.
No way I would pay 700 for a bl and level. I paid 700 for a 6" suspension install.
Good luck.
Yeah I figured $700 was way too much.. I looked at the directions online and it doesnt seem too difficult to install it myself but I dont wanna mess anything up bc I have never done anything like that but I have a few friends at a Tires Plus shop and Im gonna call and see if I can bring it to them and have them look at it. I didnt realize it was more of an issue to install than to buy haha Im in college so I dont have to much money to play around with so hopefully I can get it put on for a good price! But yeah, I was kinda looking more of what you did Brad519, just find someone I can pay under that table, that would help out a ton!
That's a little high I think. I was looking at the same combo as you so I called around and I got labor quotes of $1,200 $1,600 just for the level and BL, so I emailed Dave at Zone and he found me a local shop that quoted $750 parts, labor, and alignment. So maybe a little high but not horribly bad.
I paid right around $630 for 3" body lift, 2" level, wheels and tire install. The invoice did show them only charging labor for the body lift and level install however and not the wheel and tire install so idk. But in my eyes I paid that much for everything
I personally would recommend to do it yourself. Leveling kit should only take at the most an hour. And the body lift should only take maybe a day to do by yourself. I would never pay someone to do a body lift or leveling kit because they like to overcharge you. All you have to do is take your time and follow the directions.
my local shop quoted me 1,000 CANADIAN FUNDS! to intall a 2'' leveling kit, rear blocks and a 3'' body lift...i know they need to make money because buissness is buisness but... your looking at 10 hrs MAXIMUM to install these parts...thats $100 an hr, a bit much if you ask me..then when i told him i could do the work myself just didnt really want to mess with the warranty and what not and that i know how long these parts take to install he kind of zipped his mouth and said "well ya know give or take a few dollars"
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
