Thinkng Of Goin Racin
JFB423
What would be anyones guess on 1/4 times 2010 1500 CC w/6.2 4wd and 3.73 gears
with mild tune
I'll go with about 15.6-15.7. Maybe faster. But, anyway, I'll race you. I love racin'.
when iam down that way ill look ya up lol :rant::fume:
  • 2 months later...
Well finally went to track. I chose Island dragway in Great Meadows NJ
1st run in/ 2wd 2nd run in 4wd
60'- 3.113/ 2.115
330'- 8.354 /5.966
1/8- 12.128/ 9.186
mph- 67.82/ 76.40
1000'- 15.146/ 11.96
1/4- 17.614/ 14.318
mph- 91.73/ 95.20
1st run it spun alot
2nd run alittle better
Both runs were do on stock 17" aluminum wheels w/265/70/17 wrangler at/s's
My question is if I were to put less agressive tires on truck would time(s) change
Of course if DR's were on rear I believe out come in 2wd would be different but how much? :rollin:
  • 3 weeks later...
i wish i could race too. well im pretty sure i could take greg in that 98. ive beaten many GMT400's.
idk about tyler in the 6.0. i have raced and beaten stock 2500's. not any modded ones.
wingnut, if its the goat your talking about, ill walk away with my tail between my legs
Wuss. :uhoh:
I'll run anybody. Even a twin-turbo Viper. Just to see it go.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
