Chevron Dexron Vi Atf
I just received feedback from the Chevron Technical Support Team and the Chevron Dexron VI
ATF fluid is a full 100% synthetic ATF fluid. Out here in Oregon, the Fred Meyer Chain sells it
for $4.79 per quart. The Valvoline Dexron VI is going for $6.00 per quart. For all GM transmissions post 2006
requiring Dexron VI.
FYI--
FYI--
why do they "require" dexron??? Gm must have their fingers in something making money off of it somehow...but if their actually is a reason why i would like to know....
FYI--
They wanted the TES-295 level fluid without having to pay Allision for the certification.
The Dex 6 fluid spec is indeed GM but they own the certification specs and do not have to pay Allision.
hmm...interesting. im now using Royal Purple ATF, how do you guys think this stuff stacks up against it? i dont even know what was in it before...this was the first time i changed it. did a full flush than put royal purple in. i gained MPG...should i go back to this stuff? it sounds leaps and bounds ahead of everything else eh? all you old timers are using it i bet eh!?!?!?! :cheers:
