Zone 1-1/2" Body Lift
Couple questions:
+If a Zone 1-1/2" BL is installed, are you able to return your truck back to its original condition?
+What is the part number for the bumper bracket (figure 17 of the below link)? If possible, I'd like to buy new ones and modify it before the rest of the work since I don't know how to weld. http://zoneoffroad.com/Instructions/C9150.pdf
No welding required, absolutely none. Cutting of stock bumper bracket yes, but you can buy new ones for just a hair over 23 dollars.
Got a link? GMPartsDirect, if I am looking at the right part, has them for ~$42 each. $23 each is much better!
If I purchase new ones, I can have one of our welders take care of the welding for me and then do the install and keep the originals.
Now to find out what I would need to do to replace the rear bumper bracket, which requires cutting. Looks like:
Part #11:
Collision Catalog - 2008 - Chevrolet/Geo - Silverado 1500
Rear bumper, Bumper and components, Reinforcement, 1/2 ton, 1/2 ton $150 @GMPD.
im also thinkingabout doing 1.5". 3" just looks like to much to me
That, and I really don't want my bed that far off the ground. Many parking garages in this area are as low as 6'8".
Now if I could just found out where they sell $23 front bumper brackets, I would be set.
The brackets were quoted from New Bern Colision center NC where I got my rear end and bed side replaced after my accident. They are right next to Trent GMC of New Bern NC. Eastern NC Members know where this place is at
New Bern Collision Center?-
1709 US Highway 70, New Bern, NC? - (252) 638-5375?
I am still trying to figure out what you need to weld.
You need to weld gussets to the cut bumper brackets it's in the directions
No welding in the directions on their site.
:thumbs:
Read and understand all instructions and warnings prior to installation of product
and operation of vehicle.
Zone Offroad Products recommends this system be installed by a professional technician. In addition to these instructions, professional
knowledge of disassembly/ reassembly procedures and post installation checks must be known. Minimum tool requirements
include the following: Assorted metric and standard wrenches, hammer, hydraulic floor jack and a set of jack stands. See the "Special
Tools Required" section for additional tools needed to complete this installation properly and safely.
Product »» Safety Warning
Certain Zone Suspension Products are intended to improve off-road performance. Modifying your vehicle for off-road use may result
in the vehicle handling differently than a factory equipped vehicle. Extreme care must be used to prevent loss of control or vehicle
rollover. Failure to drive your modified vehicle safely may result in serious injury or death. Zone Offroad Products does not recommend
the combined use of suspension lifts, body lifts, or other lifting devices.
You should never operate your modified vehicle under the influence of alcohol or drugs. Always drive your modified vehicle at reduced
speeds to ensure your ability to control your vehicle under all driving conditions. Always wear your seat belt.
Technical Supp ort »»
Live Chat provides instant communication with Zone tech support. Anyone can access live
chat through a link on www.zoneoffroad.com .
www.zoneoffroad.com may have additional information about this product including the latest
instructions, videos, photos, etc.
Send an e-mail to [email protected] detailing your issue for a quick response.
888.998.ZONE Call to speak directly with Zone tech support.
Pre-Installation Notes »»
1. Special literature required: OE Service Manual for model/year of vehicle. Refer to manual for proper disassembly/reassembly procedures
of OE and related components.
2. Adhere to recommendations when replacement fasteners, retainers and keepers are called out in the OE manual.
3. Larger rim and tire combinations may increase leverage on suspension, steering, and related components. When selecting combinations
larger than OE, consider the additional stress you could be inducing on the OE and related components.
4. Post suspension system vehicles may experience drive line vibrations. Angles may require tuning, slider on shaft may require replacement,
shafts may need to be lengthened or trued, and U-joints may need to be replaced.
5. Secure and properly block vehicle prior to installation of Zone Offroad Products. Always wear safety glasses when using power tools.
6. If installation is to be performed without a hoist, Zone Offroad Products recommends rear alterations first.
7. Due to payload options and initial ride height variances, the amount of lift is a base figure. Final ride height dimensions may vary in
accordance to original vehicle attitude. Always measure the attitude prior to beginning installation.
»»Zone Offroad Products • 3 Grahl Dr., Coldwater, MI 49036 • 888.998.ZONE • www.zoneoffroad.com
rev042909
C9909# Installation Instructions
2007-09 Chevy/GMC, ½ Ton, Crew Cab, 2/4wd
1.5" Rear Bumper Bracket Kit
Difficulty Level
easy 1 2 3 4 5 difficult
Estimated installation: 1-2 hours
Special Tools Required
Reciprocating Saw or Equivalent
C9909 Installation - pg. 2
Kit Contents
Qty Part
2 1.5" x 2" Bumper Spacer
1 Rear Bumper Bracket (drv)
1 Rear Bumper Bracket (pass)
1 Bolt Pack - Rear Bumper
THIS BUMPER MOUNT KIT IS DESIGNED FOR USE WITH ZONE OFFROAD 1.5"
BODY LIFT KIT #C9150 OR COMBO KIT #C1350. PERFORM THIS KIT INSTALLATION
AFTER THE BODY LIFT OR COMBO KIT IS INSTALLED IN THE VEHICLE.
INSTALLATION INSTRUCTIONS
1. Park the vehicle on a clean, flat surface and block the rear wheels for safety.
2. Lower the spare tire and remove it from the vehicle. See vehicle owner's manual for
spare removal procedures.
3. Locate the rear wire connector cluster on the rear, driver’s side frame crossmember
Figure 1. Disconnect the license plate light harness and back-up sensor harness (if
equipped).
Figure 1
4. If equipped, disconnect the trailer wiring connector from the bumper Figure 2.
Figure 2
C9909 Installation - pg. 3
5. If equipped, remove the two bolts mounting the rear bumper to the receiver hitch
Figure 3.
Figure 3
6. Remove the 4 bolts (8 total) mounting the rear bumper to the frame rails. 3 are accessed
from the side of the frame Figure 4A and one up through the bottom Figure 4B.
Remove the bumper from the vehicle. Save all hardware.
Figure 4A
Figure 4B
C9909 Installation - pg. 4
7. The rear bumper must be modified to install the new rear bumper brackets. Measure
back on bracket from the edge of the bottom tab (tab that goes against the bottom
surface of the frame) 4-1/2” and make a vertical cut line Figure 5. Cut the end of the
bracket off along the line. Remove any burrs and paint exposed metal to prevent corrosion.
Note: Bumper is shown upside down in picture.
UP
Figure 5
8. Locate the existing hole and slot in the bumper bracket that was trimmed Figure 6.
These are located farther inside the bumper. Attach the new provided bumper
brackets to the bumper using these existing holes and slots. Fasten the new brackets
to the factory bracket with ½” x 1-1/4” bolts, nuts and ½” SAE washer. The brackets
should mount to the inside surface of the factory bracket and offset toward the
outside of the bumper Figure 7. Adjust the brackets so they are visually square with
the top edge of the factory bracket and snug hardware.
Figure 6
9. Using the new bumper brackets as templates. Mark the third bracket mounting hole
to be drilled Figure 7. Remove the brackets and drill a 1/2” hole at each mark.
C9909 Installation - pg. 5
UP
Figure 7
10. Reinstall the bumper brackets on the bumper with the same hardware along with an
additional ½” x 1-1/4” bolt, nut and washers for the hole just drilled. Leave hardware
loose.
11. If equipped with a receiver hitch: Fasten the receive hitch to the bottom of the frame
rails through the rear-most holes using the provided 5/8" x 1-1/2" bolts, nuts and
5/8" USS washers. Figure 8 Torque bolts to 100 ft-lbs.
Figure 8
12. Install the modified rear bumper in the vehicle Figure 9. Be sure the new brackets
are inside the frame rails and the spare tire winch tubes align Figure 10. Fasten the
bumper to the original frame mount holes with the factory bolt tab and nuts. Fasten
the bracket through the remaining front-upper hole Arrow - Figure 10 with the original
10mm bolt and provided 10mm nut and washer. Leave hardware loose.
Figure 9
C9909 Installation - pg. 6
Figure 10
13. If equipped with a receiver hitch, install the provided 1.5” tall x 2” OD bumper
spacers between the hitch and the bumper. Figure 11 Fasten the bumper to the hitch
with 14mm x 80mm bolts and 9/16” SAE washers. Leave loose.
Figure 11
14. Tighten all bumper mounting hardware starting with the bumper-to-bracket hardware
first. Torque the hardware to the following specs: ½” and 12mm hardware – 65
ft-lbs, 14mm hardware – 95 ft-lbs, and 10mm hardware – 40 ft-lbs.
15. Reconnect all bumper wiring.
Post-Installation
1. Check all hardware for proper torque.
2. Check hardware after 500 miles.
:thumbs:
rev042909
Difficulty Level
Kit Contents
Qty Part
3. Locate the rear wire connector cluster on the rear, driver's side frame crossmember
equipped).
Figure 1
Figure 2
Figure 3.
Figure 3
Figure 4A
Figure 4B
surface of the frame) 4-1/2" and make a vertical cut line Figure 5. Cut the end of the
UP
Figure 5
to the factory bracket with ½" x 1-1/4" bolts, nuts and ½" SAE washer. The brackets
Figure 6
to be drilled Figure 7. Remove the brackets and drill a 1/2" hole at each mark.
UP
Figure 7
additional ½" x 1-1/4" bolt, nut and washers for the hole just drilled. Leave hardware
loose.
Figure 8
Figure 9
Figure 10
13. If equipped with a receiver hitch, install the provided 1.5" tall x 2" OD bumper
with 14mm x 80mm bolts and 9/16" SAE washers. Leave loose.
Figure 11
first. Torque the hardware to the following specs: ½" and 12mm hardware – 65
Post-Installation
The welding is for the front bumper brackets. If you read the body lift instructions its in there. Originally he had asked if you could return to OE after installed the body lift kit. I saw the welding, didnt realize the brackets were replaceable. Thats where you have to weld in gussets.
:thumbs:
From the link in the original post:
39. Locate the provided bumper bracket gussets. The gussets will be welded between
Thanks for the info on the brackets, I'll look around locally to see what I can find.
the front face of the factory bracket and the center tube. Remove paint from these
areas to promote good weld penetration. The gusset should be set in about 1/8 to
1/4" from the cut edge. Weld the gusset in place.
Ah front end brackets! I am a dumb arse. I was looking at the rear.
I have a set of front brackets sitting here in the garage if you want them let me know PM if interested and I will send pics for you. They are from a GMC but if they should work.
Correction, I was looking at the wrong part, I believe this is the corret one:
Spacer Back - Chevrolet 1/2 ton - Chevrolet 1/2 ton
07-10 $21.29
#5:
    • Whoever greenlighted the work truck matte black front bumpers on every trim but the AT4X should be fired!  I was hoping that was an AI mistake, but just realized they were on every model of the 2027 Silverado too.     Some parts of the interior do look premium, but the Denali Ultimate dashboard looks like an afterthought.  At least they appear to have lost the microfiber the high end Silverado models showed, but the '27 High Country dash looks better than the Denali.
    • New member here. I am researching a read-first event-recorder concept for late-model GM V8 trucks. This is not a sales post. There is no product link, price, preorder, or mailing list. I am trying to determine whether the underlying problem is real before building anything.   Has your truck ever had a brief problem such as: - rough running or a momentary misfire - an oil-pressure warning or unusual pressure event - reduced power or a brief stall - a U-code or lost-communication problem - a symptom that disappeared before the dealer or independent shop could reproduce it   If so, I would appreciate the following details: - year, model, engine, and mileage - what happened and under what conditions - whether a DTC and useful freeze-frame data were stored - whether the shop was able to reproduce it - what the eventual confirmed repair was, if known - what additional information would have helped the diagnosis   The concept being evaluated is a removable leave-in recorder that continuously retains a rolling window from before and after an event. It would not tune, reflash, clear codes, or change the vehicle calibration.   I am also not claiming that it could predict lifter failure or see every internal ECM variable.   The real question is whether continuous event history would add enough useful evidence beyond freeze frame, GDS2, and existing scan tools — or whether it would simply be another unnecessary gadget.   For owners and technicians, which problem would make something like this genuinely useful: 1. intermittent misfire or AFM/DFM-related behavior 2. oil-pressure events 3. lost communication or electrical faults 4. none of the above Please be blunt. Negative feedback is just as useful as positive feedback.
    • No tears over the SLE and SLT trim levels disappearing but I kind of loathe the "Elevation" name. It's a truck--skip the elegance.   The slab-dashboard design is decidedly different. Almost has a Hummer flavor to it. "Professional Grade" seems to be leaning very white-collar, tech-driven these days moreso than blue-collar, functional design.   The Silverado would be my choice between the two new trucks. Pleased with the engine lineup in both. The GMC is a little "too much" for a truck, IMO, and the Denali borders on ridiculous - but I do know there are buyers for luxury trucks out there. It's just not my speed.
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
